06-04-2008, 15:01 | #1 (permalink) |
Major Poster Join Date: Jan 2008
Member: 678649 Status: Offline Thanks Meter: 3 | N70 white screen I got 2 N70 with the same problem.Only white screen appear..after a while the start up tone heard but not till the end n keep hanging. I've checked out the posted method in repairing white screen but i wanna know which method exactly i should use..or i jz need to change the LCD ic. I did flash 1 of the phone but failed n now the phone doesnt appear anything when turn on.help me plz.. |
The Following User Says Thank You to Chan Ho Nam For This Useful Post: |
06-04-2008, 15:23 | #4 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | This seems not to be a LCD problem. If this phone cannot be flashed/is death after flash, try to rehot flash, RAM, if dont help, rehot everything what is not glued to PCB. If phone is fully working, only LCD is blank, change both filters under LCD, near backup battery, remove the battery first. |
06-04-2008, 15:41 | #5 (permalink) |
Member: 678649 Status: Offline Thanks Meter: 3 | I didnt save the flashing logs.I flashed the phone with HWK box.B4 i flash the phone..check n Info status is ok...but after flash (flashing activities turned error while on the run) the phone cannot turn to local mode.check status is ok but Info is failed.I've tried to flash but still failed cos the phone cannot get into local mode.when i turn the on switch,it doesnt appear anything. |
06-04-2008, 15:44 | #6 (permalink) | |
Member: 678649 Status: Offline Thanks Meter: 3 | Quote:
I'm working on it,thanx 4 the guide.I wish it could help... | |
N70 white screen plague | roglio | Nokia Base Band 5 ( BB-5 ) | 20 | 04-04-2007 17:20 |
Nokia N70 white screen after flash | buegi | Nokia Base Band 5 ( BB-5 ) | 2 | 10-10-2006 14:45 |
N70 White Screen | chardex | Nokia Hardware & Hardware Repair | 13 | 09-19-2006 11:15 |
Nokia N70 White Screen | fusion007 | Universalbox | 4 | 07-13-2006 22:35 |
n70 white screen >>>>>error | djyash | MT-BOX | 3 | 07-04-2006 10:32 |
