Old 08-20-2007, 11:06   #1 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
6300 to mouch heat..?
hi to all aney idia your 6300 to much heat...end no battery bls..i have call 5,to,20 minet...bettery low end heat...aney idia what problem this models..
this compani diflts but aney salusion this meter..plz help what can i do....?
Old 08-20-2007, 16:07   #2 (permalink)
Member: 172811
Thanks Meter: 135
i think you have a short in the battery pins. check it with multimeter, if shorted
try to remove the PA ic 1st , and so on ...
Old 08-21-2007, 14:28   #3 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
sir thankx to guide , to mouch 6300 same problem ,its barands new pis...1000 pis same all pis cheng, pa .sir..?
Old 08-21-2007, 14:57   #4 (permalink)
Member: 542287
Thanks Meter: 20
ok you shoud ,reinstalled software by hwk into it,thanks
Old 08-22-2007, 23:39   #5 (permalink)
Member: 88790
1st try to change pf
Old 08-23-2007, 08:18   #6 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
check the battery connector with ur multi meter its shorted or no,if shorted i think the PA ic is damaged just change it...Good luck!!!!
Old 08-23-2007, 08:53   #7 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
it is not necessary that all new pic are OK, check the batter connector if short change the PA
Old 03-15-2008, 16:34   #8 (permalink)
Member: 722217
sir i've check the battery connector but it's ok...is it still PA is damage???any solution??? same problem here....
Old 03-15-2008, 17:07   #9 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
" let i tell u the most important point abt nk 6300 when it struck the market, it gets the negative response from customers after using becz of the following reasons they are * cracking sound while making a call & * the set gets heat up while making a call or while listening music etc then after few days comes the response from nokia corporation to there care centres & the response was change the software problem will be solved but the effect of there response was less & at last the product loses its identity from the market even the price were slashed very much. so bro dont go for hardware, change files of higher version it may or may not solve the problem becz it is manufacturing problem to most of its initial lot"
The Following User Says Thank You to mobilespeed For This Useful Post:
Old 03-15-2008, 17:43   #10 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
you are ok mobilespeed
Old 03-15-2008, 17:53   #11 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
dear change first PA
from any nokia6300 dead board.
Old 08-30-2008, 11:25   #12 (permalink)
Member: 429744
Thanks Meter: 93
any body help me nokia 6300 keypaid jumper soulation i have change key paid ic and volumes key but problems is same .
Old 02-04-2011, 13:19   #13 (permalink)
EMOTION BBSR's Avatar
Member: 194285
Thanks Meter: 53
nokia 6300 keypaid ic is ok but not work keypaid
6300 getting heat md jawad Nokia Hardware & Hardware Repair 4 10-30-2009 06:31
Nokia 6300 after heat or remove cpu mobile is dead help me gsmhosting Nokia Base Band 5 ( BB-5 ) 0 04-18-2009 17:04
6300 heat on flash Mohsin-* Nokia Hardware & Hardware Repair 3 04-17-2008 09:13
How can I downgrade 6300 to 4.70 safe? dadustar UID - Box 5 09-08-2007 20:04
Flashing Nokia 6300 to FW v5.00 with NSS jules_winnfield Nokia Base Band 5 ( BB-5 ) 0 07-10-2007 23:02
Page generated in 0.25861 seconds with 9 queries
