10-08-2010, 17:12 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,694 | 6300 strange problem ..... please |
10-08-2010, 18:44 | #3 (permalink) | |
Insane Poster Join Date: Aug 2008 Location: gujrat
Member: 843808 Status: Offline Sonork: jain Thanks Meter: 11 | Quote:
10-09-2010, 16:39 | #7 (permalink) |
Member: 772651 Status: Offline Thanks Meter: 1,694 | this set had come to me with contact service if firstly checked the reason of contact service .. it had security test failed .. i took its rpl book then i started with pm 1 & 309 with sx4 auth. and sx4 auth. was successfully done but authorised pm failed to write then i thought to flash it with v7.30 .. it got flashed with ufs but ui setting failed due to which set is not on but with side lights only .. the i tried it with mt-box same flashing completed but factory setting failed .. then i flashed it with dead usb by universal same at the errors end of flashing, then i flashed it with jaf same condition , lastly i tried it with mx-key .. same boot loader not responding ... now i am frustrated what to do with this set [6300] |
10-09-2010, 17:26 | #9 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Paradise on Earth
Member: 1281866 Status: Offline Thanks Meter: 330 | clean board with chemical you have and give suficent heat to thavo cpu and combo memory once try check try to bush check only if succeed then take following step only when you have rpl back up First of all erase your handset after erasing flash with latest version you have and do factory settings with ub power supply of ub is necessary it helps the handset to go into local mode which is need of factory setting |
01-14-2011, 14:36 | #10 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | 6300 contact service security test fail if you all normal procedures are fail then do see and adopted http://forum.gsmhosting.com/vbb/f550...7/#post6825990 thanks to you all by gsmzaman |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
