02-18-2010, 10:43 | #1 (permalink) |
Junior Member Join Date: Nov 2008
Member: 899253 Status: Offline Thanks Meter: 4 | 6303 bluetooth+camera+video playing today a strange problem faced me nokia 6303 the camera does not play and shows the camera on standby and does not work the video and bluetooth please can you give me the right solution with my best regard |
The Following 3 Users Say Thank You to ramiii84 For This Useful Post: |
02-18-2010, 13:31 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Bro.try this solution. http://forum.gsmhosting.com/vbb/showthread.php?t=912088 |
The Following 16 Users Say Thank You to mahbubalfa For This Useful Post: |
02-18-2010, 18:22 | #4 (permalink) |
Member: 899253 Status: Offline Thanks Meter: 4 | thanks brother for your concern but as you see it is 3 problem at the same time and it is the second time i faced the same problem and i could not fix it may the problem from the camera parts or bluetooth parts or some thing sharing between them |
02-19-2010, 12:53 | #6 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 906499 Status: Offline Sonork: sen-i Thanks Meter: 47 | it is baterry conector . it is faulty and have broken all contact to bluethooth and cam. i have 1 6303 , but wont repaire this it is very hard , people can make it . but not easy |
The Following User Says Thank You to sen-i For This Useful Post: |
02-22-2010, 17:36 | #9 (permalink) |
Freak Poster Join Date: May 2003 Age: 48
Member: 29870 Status: Offline Thanks Meter: 24 | yes,seems it is fault of battery conector but how can we repair it.I think there is lost line from BSI pin. |
The Following User Says Thank You to SRNOURI For This Useful Post: |
02-23-2010, 09:44 | #10 (permalink) |
Member: 906499 Status: Offline Sonork: sen-i Thanks Meter: 47 | not bsi line, all way under baterry connector , for me it was 5 way under "-",9 way under "bsi" , and 2 way under "+". very hard work . i have back the phone , but if you have guaranti for phone go to nokia service and i think it is nokia fault for this model. they need replased mainboard , or repair this , conector is lose bks , oil was under conector and it was not ok |
03-03-2010, 20:41 | #11 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: libya Age: 44
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | Quote:
BIG GSM FORUM with 1,250,244 Members no solution no post reply ( reading only and leave ) where Moderators ? Where experts ؟ big problem w/o solution ( 6303 bluetooth+camera+video playing problem ) Do not skimp on helping others best regards for all my friend | |
The Following User Says Thank You to Gsm Benghazi For This Useful Post: |
03-03-2010, 20:52 | #12 (permalink) | |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | here phone test by mx-key Quote:
03-05-2010, 22:32 | #13 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | In Nokia Hardware & Hardware-Repair section no post reply where all Moderators ? ( Pandemonio100, Raheeeeb, stanner_austin, Drug_Store, ..::Neo::.., Syed, simonng83, ..::ArchitRaj::.. ) no one here no regards |
03-05-2010, 23:30 | #14 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | HERE SAME PROBLEM http://forum.gsmhosting.com/vbb/show...highlight=6303 http://forum.gsmhosting.com/vbb/show...highlight=6303 http://forum.gsmhosting.com/vbb/show...highlight=6303 BEST ANALYSIS BUT HOW CAN WE SUBSTITUTE THIS track ? |
03-07-2010, 16:52 | #15 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | here last solution Try careful heating of RAPGSM+Combo memory stack and HWA to check for a soldering issue. Test the camera function after this action. If the camera still does not work, then a track below the battery connector has been damaged the track below the battery connector has been damaged It is not possible to repair these internal tracks |
The Following 4 Users Say Thank You to Gsm Benghazi For This Useful Post: |
6303 bluetooth+camera+video not playing help need | abdurrahimsagar | Nokia Hardware & Hardware Repair | 15 | 09-11-2013 20:25 |
6300 blue tooth+camera+video playing | abdurrahimsagar | Nokia Hardware & Hardware Repair | 5 | 05-20-2011 13:59 |
6233 camera and play video after restart solution 100% ok | hajukhan | Nokia Hardware & Hardware Repair | 14 | 05-08-2011 10:25 |
hı..help 6500 not video playing and camera | proton | Nokia Hardware & Hardware Repair | 1 | 01-07-2010 19:22 |
6500s Camera not working and no video play | Pratheesh T K | Nokia Hardware & Hardware Repair | 0 | 12-17-2009 14:51 |
