01-02-2004, 00:31 | #1 (permalink) |
Junior Member Join Date: Jan 2004 Location: England Age: 43
Member: 48012 Status: Offline Thanks Meter: 0 | 7210 powers up but no display I've got a 7210 which powers up but just shows blank screen. I have tried flashing with 4.74 firmware with cheap china flasher but still nothing. Do I need to change the lcd or is this because cheap flasher is not good enough to solve problem? thanks to all. |
01-02-2004, 13:37 | #5 (permalink) |
Member: 48012 Status: Offline Thanks Meter: 0 | thanks ppl. i'll try changing LCD and see if that helps. if not I might get a more powerful flasher. Compaq, how do I reset phone? I've tried resetting security code but no joy. cheers, Dave |
01-08-2004, 21:18 | #10 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | its not software problem its lcd connector .. test the legs of board lcd connector with the nine test points under it and sure its onnected you ll find only one o connection don't panic its nc leg if not you have to change the upp |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
V3:when power on I hear that is on but no display. | beneto | Motorola Hardware Repair | 0 | 09-23-2008 18:50 |
Philips SC201 lights up but no display | peterallis | CAR Electronics | 0 | 11-01-2006 14:47 |
7210 flashing done but no power on??? | Alim Hape | Nokia Hardware & Hardware Repair | 5 | 04-24-2005 11:23 |
7210 Flashing Ok but no power on! | Ercie | Nokia Hardware & Hardware Repair | 6 | 02-18-2005 01:01 |
