02-11-2004, 10:54 | #1 (permalink) |
Major Poster Join Date: May 2002 Location: portugal Age: 48
Member: 11612 Status: Offline Thanks Meter: 0 | 6310i not charging can somebody give help in that problem please . i have a 6310i work ok but not charging , the charger is cool and i update soft with griffin to a new version but still the same . i chek the fuse in boton of bord and it's good . what cab i do more to repaie that problem ? best regards |
02-11-2004, 11:09 | #2 (permalink) |
Freak Poster Join Date: May 2003 Location: In between some long female legs
Member: 28095 Status: Offline Thanks Meter: 0 | Check the connector itself, clean it, make sure there is good contact to the board. Of course this is not the only solution, but im sure some1 else will be along shortly to point you to some other hardware that may need looking at regards NaaN |
02-11-2004, 19:27 | #4 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Yes it is from charger to the UEM , 1st try other charger or charge it with other phone to be sure it is working. If the phone doesnt sign NOT CHARGING Check F100, L100, V101 ,C107. If the phone gives Not Charging , Check UEM !!! |
02-19-2004, 13:45 | #7 (permalink) |
Member: 11612 Status: Offline Thanks Meter: 0 | i do a check at all phone and i presume is UEM " **** " becouse i tried wiht another charger fuse and i have the same result's . when i conetc the charger on the phone if i check the voltage in connector to baterie and i just have +- ~1 volts , because that i think is uem |
Nokia 6310i not charging | market_3b2002 | Nokia Hardware & Hardware Repair | 16 | 04-04-2007 15:07 |
6310i not charging | bebiloku | Nokia Hardware & Hardware Repair | 5 | 07-27-2006 05:07 |
Nokia 6310i not charging | market_3b2002 | Nokia Hardware & Hardware Repair | 3 | 02-23-2006 14:49 |
Nokia 6310i not charging!! | MC Harami | Nokia Hardware & Hardware Repair | 8 | 11-14-2005 13:09 |
6310i NOT CHARGING | sjakie | Nokia Hardware & Hardware Repair | 1 | 09-17-2005 11:59 |
