6310i problem after flash 6310i have a problem before flashing, sometimes he will not go on, now i have flash and try to do def def but phone will not reboot, try it many times, flash with different flashfiles try 3 pc but nothing works, whats the problem? |
try to check your flash ic or replace it after replacing try to rebuild your imei coz it will be ?????????? ,after rebuilding you could have your phone working normaly |
rebuild your imei ??? must i change uem? i think thats not the problem, imei are not ??????? and the phone works before flashing, someone else a solution? |
check flash IC or Hager sure there is one fulty |
ok tell me where is the hagar, 6310i has no hagar tony montana, change flash ic is a big problem for me, always trouble if i do that, i rehot mjoelner, flash ic but same problem, and now? |
try to replace flash ic,tested by me. after changing flash ic rebuid your imei using twister it works... hope this could help |
@gsm style i will tell you something important for 6310i!!!!!!!!!!!!!! another time when you have 6310i.. you must see better the bloototh works or not ?(freeze) becouse if not works (when your phone is on ) after one flash the phone must be off (like yours )its 100%tested. and your solution now is if you have another 6310i dead you must change the bloototh ic in the pcb and reflash the phone must be 100% ok i dont know if you understand me ?? best regards keany |
i understand you, don't now or the bleutooth works from this 6310i, i have an other 6310i dead, must i change the whole thing just like at the picture? |
yeah you try now to change the blotooth ic from other 6310i and reflash the phone . |
