05-06-2009, 14:43 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 263709 Status: Offline Thanks Meter: 327 | 6500c classic Charging Solution.. 1. check Strip First. 2. Remove R2010 3. Change N2000 or Make jumper as in picture.. |
The Following 86 Users Say Thank You to basilbaby For This Useful Post: |
05-11-2009, 06:44 | #5 (permalink) |
Freak Poster Join Date: Sep 2008 Location: +060146324283 . Malaysia Age: 39
Member: 860925 Status: Offline Sonork: Now I'M Malaysia Thanks Meter: 294 | Thanks Bro Nice Post Keep It Up........... |
The Following 2 Users Say Thank You to billal1050 For This Useful Post: |
05-11-2009, 06:55 | #6 (permalink) |
Member: 263709 Status: Offline Thanks Meter: 327 | Dear brother..Remove R2010 , If the charging contacts are short only.. This jumper can bypass N2000. I got lot of 6500c having problems with n2000. This jumper also solves "battery Not full Problem".. |
The Following 4 Users Say Thank You to basilbaby For This Useful Post: |
06-06-2009, 16:00 | #8 (permalink) | |
Major Poster Join Date: Mar 2007
Member: 470525 Status: Offline Thanks Meter: 4 | Quote:
i have tried this solution and worked 100%, but it charging and make full batteries when i charging at on condition. when i try charging the hp at off condition, hp blinking white and goes off, and white and goes off.. again and again. any solution?? | |
The Following 2 Users Say Thank You to esbatu For This Useful Post: |
06-18-2009, 20:23 | #11 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: UK
Member: 395587 Status: Offline Thanks Meter: 63 | Quote:
Before they were all working apart from charging. When I tried this solution charging was ok but *******rs came back after a day and said phone wont power on now and is very hot. Checked them out and yeah in all handset betty is shorting. In one came back I changed betty and phone ok but dont think charging will be all right with this sol. Ive got one in shop I fixed by this sol and will check it totally out tomorrow how its charging etc.and will check shematic as well to find out whats happening there. Please double check ur solution cos I think is not right. Did the same happend to anyone? Please share with us cos I think is a really common fault with 6500cs. (only I had 5 in 2 weeks with charging prob on board) | |
06-21-2009, 19:11 | #13 (permalink) | |
Its weird why 3 phones gone dead with betty. Changed bettys in them, removed jumper and all working fine (charging too). | |
06-22-2009, 07:15 | #14 (permalink) |
Member: 263709 Status: Offline Thanks Meter: 327 | Dear brother, i am not clear about your problem. This jumper is applied before betty,by passes circuit including n2000. You can see it in schematics. And i am sure that replacing betty cant solve changing problem related to the circuit containing n2000. You can test it by changing betty before applying jumper.. have a good day!!! |
The Following User Says Thank You to basilbaby For This Useful Post: |
6500c latest charging solution here.......wow | chohansahib | Nokia Hardware & Hardware Repair | 12 | 05-05-2012 07:55 |
Nokia 6500c fake charging.charging not save solution | mahbubalfa | Nokia Hardware & Hardware Repair | 12 | 05-08-2011 10:47 |
6500c latest charging solution here | Dooha_Bd | Nokia Hardware & Hardware Repair | 1 | 02-10-2010 10:47 |
6500c no charging | adnanmughal | Nokia Hardware & Hardware Repair | 3 | 03-07-2009 08:51 |
Is 6500c CLASSIC RM-265 support with S60 and SL_2 Unlock??? | KhOliO | Universalbox | 2 | 12-18-2008 07:35 |
