6500s keypad do not work 1,4,7,*,0 hello help please 6500s do not work keypad 1.4.7.*.0 , is posible jumper ic keypad, thanks, sorry my english, country Paraguay |
thanks man pero no work, make jumper to ic keypad and ic driver for 0 * # and no work, mismo problem, :confused::confused::confused: any idea? |
a make jumper picture for 0 * # pero al presionar keypad 4 sale *4, al presionar 5 sale 05, y al presionar 6 sale #6, and no work 0 * # Thank any idea |
bro maybe your keypad ribben problem,,,, you also can try this::::http://www.usaupload.net/d/e1oxpmi1qab regards gsmshare |
try to change the keypad ribbon... i did one, change keypad flex no luck.. when i look the keypad ribbon at the microscope it has cut.. so i change the keypad ribbon.. problem solved.. |
yup 100% keypad ribbon.... |
I have a nokia 6500s that was not charging. I re-soldered the fuse and it works but then I could only turn on the phone but could not press the middle button to accept turning on. Also I could turn it off but nothing else. I changed the top keypad ribbon but still can not press the middle button to accept. Many thanks |
no lcd flex 1000000% ok |
On the top keypad only the hangup (power on/off red) key seems to work, so the phone is in a unusable state. I can't seem to find a working solution for this problem. Can anybody help me on this? |
@luis. Hi try and check side colume switches!maybe its getting stuck!i had 5 sets with same problem.post result? |
