01-13-2010, 03:03 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1207548 Status: Offline Thanks Meter: 0 | 6500s keypad problem 1 4 7 din * action taken change ic no lock we dont have flex do u have some lay out off keypad flex thanks |
01-13-2010, 03:56 | #3 (permalink) |
Member: 1199105 Status: Offline Thanks Meter: 7 | brother its lost contact only just remove then put it back or just press to the connector of the flex cable to the board connector and it will be ok.. last sulotion change br. |
02-17-2010, 11:17 | #14 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GSMFORUM Age: 37
Member: 1133716 Status: Offline Thanks Meter: 282 | Here you can see where the keypad ic many thanks to MASTER to post this solution The original link is:http://www.gsmsandwich.com.ph/forum/...500s+keypad+ic |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
nokia 6500-slide keypad problem | djems | Nokia Hardware & Hardware Repair | 29 | 12-07-2012 18:15 |
6500 slide keypad problem | lijgeorge | Nokia Hardware & Hardware Repair | 13 | 04-27-2010 07:36 |
nokia 6500s keypad problem | eroll78 | Nokia Hardware & Hardware Repair | 2 | 05-07-2009 05:59 |
6500 slide keypad problem | lijgeorge | Nokia Hardware & Hardware Repair | 4 | 02-07-2009 06:59 |
