05-30-2009, 04:41 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: malaysia
Member: 429569 Status: Offline Thanks Meter: 1,543 | brother have u try this all way???? i know u are best,,,,i confuse ,,,,coz i am so small man,,, i very like ur solution,,,then also i know,,,u r the best ,,,,try step by step,,,, this is :::http://www.rapidspread.com/file.jsp?id=jbijlissgs regards gsmshare |
The Following 3 Users Say Thank You to gsmshare For This Useful Post: |
05-30-2009, 05:44 | #4 (permalink) |
Member: 429569 Status: Offline Thanks Meter: 1,543 | if all tracks ok,,,try use wire,,,pcb between mic,,,i know u understand what i talk,,,, i also fell shy,,,,,,coz i can't do anything,,,,,,if all tracks ok ,,,,and still mic not work,,,that is bi problem... ok bro try new mic with wire |
06-06-2009, 12:15 | #8 (permalink) |
Junior Member Join Date: Nov 2007
Member: 631978 Status: Offline Thanks Meter: 3 | hi well its simple u can get the same mic of a 5610 6500c 6500s and e90 wen u puting the mic on the board dnt put direct heat on mic heat it 4fm under the board also put solder nycly on mic tracks befor u put the mic |
06-06-2009, 14:41 | #9 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Bangladesh Age: 53
Member: 441231 Status: Offline Thanks Meter: 206 | Quote:
he known to well how put the mic in 6500s. usally 6500s mic is put dificulty i tested.so br think before post ur inform like low or high? anyway thanks for share br. B.R. | |
..::motorola c261 mic not working::.. | HUM | Motorola Hardware Repair | 8 | 01-05-2010 14:26 |
..::6500 slider down navigator not working::.. | HUM | Nokia Hardware & Hardware Repair | 0 | 08-04-2009 15:15 |
..::china n73 1st copy mic not working::.. | HUM | Chinese Models & Cloned Phones | 1 | 04-01-2008 11:42 |
..::6680 front camera not working::.. | HUM | Nokia Hardware & Hardware Repair | 2 | 06-21-2007 00:05 |
..::3250 mmc slot not working::.. | HUM | Nokia Hardware & Hardware Repair | 2 | 06-18-2007 22:15 |
