Old 01-29-2003, 16:29   #1 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
Red face 6510 displays headset!!! help
help!!!!
a headset display remains at the screen even theres no headset inserted into the unit????? i thought its a software problem but its not!!!! i even removed the terminal of the headset thinking it is the thing that causes it to display headset but still the headset is there????
any suggestions on what should i do???
thnx!!!!
br
Old 01-30-2003, 19:07   #2 (permalink)
Member: 19003
check on board where base connector make contact ...just try cleaning or try changing transistors there.....
Salaams
Old 02-13-2003, 13:42   #3 (permalink)
Crazy Poster
Member: 13268
i have similar problem...
anybody found a solution??
Old 03-13-2003, 02:12   #4 (permalink)
Member: 24500
try to change the charging block i tried once and it worked
Old 03-13-2003, 10:01   #5 (permalink)
Member: 22526
I think the cleaning will be help! Try clean the connector or rehot down the PCB. If don't work try the ultrasonics cleaner.
Good luck!
B.R.
Old 03-14-2003, 04:35   #6 (permalink)
amir-cairo's Avatar
Member: 11466
COBBA mostlly
check it (hot it by flux or change)
GOOD LUCK
Headset icon appear on display / Headset not work solution here.. capri Nokia Hardware & Hardware Repair 39 03-16-2011 14:47
nokia Headset icon appear on display / Headset not work hazar Nokia Hardware & Hardware Repair 2 10-13-2009 08:29
nokia Headset icon appear on display / Headset not work hazar Nokia Hardware & Hardware Repair 0 10-12-2009 22:38
6510 8310 headset & no signal solution ali-xander™ Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-04-2009 10:47
6510 display problem aon4f1 Nokia Hardware & Hardware Repair 0 09-22-2002 14:49
Page generated in 0.15491 seconds with 9 queries
