04-17-2010, 08:04 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 689890 Status: Offline Thanks Meter: 0 | 6510: power and charge problem Phone History: The problem was, all the switch was damage, power switch, volume up and down, What I Did: with that problem, i just replace all switches and i didn't touch any component. Problems Occurred: After replacing, when i tested it, i switch it on, sometimes it turned on sometimes it didn't, i tried to charge it but the charger was not recognize. When i tried to remove the power switch and shorted the terminal with a twizzer it turned on, i check the power switch with a tester and its ok, it has good contact. I did install again the power switch but still it won't turned on. I already used 5 power switch trying to replace but still its not working. i hope you all out there could give me a clue. im sure its not about software 'cause when i shorted the terminal, it boot up and the phone works fine. pls... advice.. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
