Old 04-30-2005, 14:41   #1 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
7210 very poor contrast, Please help!!!
7210 water demaged, I repaired the phone but now the display contarst is very poor.Hard to see texts. I changed CPU,UEM, LCD no result.LCD connector is OK 100%. I lived this problem many times on 7210,6610 and 6820. Isn't tehre any soft to increase Contrast manually like DCT3. I uploaded all software works like flash, PM full erase etc...
Plase help!
Old 04-30-2005, 18:29   #2 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
hi man! check the resistors on the picture:
Old 04-30-2005, 22:13   #3 (permalink)
Member: 16036
Thanks Meter: 5
brother
did u try MANUALLY to increase contrast?
Old 05-06-2005, 09:13   #4 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
I checked these resistors of course, changed with good resisitors, the problem is same..There should be something else..
Regards
Old 05-06-2005, 13:41   #5 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
1) sw problem (write last sw and good PM)
2) lcd (try another type)
3) connector
4) resistors
5) UPP
6) lines
check one more time and replace if possible, it must solve the problem
Old 05-12-2005, 09:39   #6 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
3) connector
4) resistors
5) UPP
6) lines
All changed, from a phone which is working good, interesting the same poor contrast, hard to see.
Old 05-14-2005, 23:38   #7 (permalink)
Member: 7586
Thanks Meter: 11
i have same problem with 6610 very poor contrast.
did u fixed it ?
Pali
Old 05-15-2005, 16:44   #8 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
well, did you check that "working good" phone has another type of lcd (there are at least 3 types of lcd - marked with green, red or blue colour)?
Old 05-16-2005, 08:07   #9 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
The reason is not LCD I am sure, I used tons of LCDs. And as I know 6610 and 7210 can use all types of LCDs.
Regards anyway....
Old 05-17-2005, 13:56   #10 (permalink)
Member: 136598
Thanks Meter: 3
did you check the connection lines between screen and board, clean it with methonal
Old 05-21-2005, 22:42   #11 (permalink)
Member: 7586
Thanks Meter: 11
conection is OK .
LCD is ok too.. (tried about 10 different lcd )
UEm ic new.
UPP is also changed.. still same.
flashes with latest fw..
Pali
Old 05-22-2005, 12:52   #12 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
did you check signals VI0 and VFLASH1?
VI0 (1st pin of lcd connector) must be 1,8V
VFLASH1 (6th pin of lcd connector) must be 2,8V
Old 05-23-2005, 07:43   #13 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
for my 7210 VIO=1.8v and VFLASH1=2.8 v I checked them first, but still very poor contrast. This is a very interesting problem. especially on water demaged phones. I saw many and could not fix. maybe under CPU there is some hole demaging.
Rgards
Old 05-23-2005, 07:52   #14 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
mmm interesting... could you send me the board? maybe i'll fix the prblm
Old 06-02-2005, 18:51   #15 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
how to send you the board brother, I have seen 10 phones with this problem..
in LOCALE MODE contrast excelent...
7210 security test failed please help cellcarekphb MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 12:42
3100 poor ringer please help me naveed malik Nokia Hardware & Hardware Repair 5 05-16-2008 22:02
it is very old but please help== **RAJESH** Infinity-Box 2 03-22-2007 21:23
7210 "Cannot undo restriction" Please help me fdsktyu Nokia Digital Core Technology 4 ( DCT-4 ) 13 06-27-2003 19:13
Page generated in 0.22032 seconds with 10 queries
