10-10-2007, 15:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Punjab, Pakistan Age: 38
Member: 264520 Status: Offline Thanks Meter: 61 | 6600 after chang BT IC, show white LCD after changing bluetooth module is show white LCD for few seconds than power off. erase using UFS and before flashing UEM+PPM uncheck bluetooth flashing option. after complete UEM+PPM done, FORMAT USER AREA and UI SETTING failed. and WSOD (white screen of death) fault is still also...is problem in the UEM chip now or in an other place...? post solution as time as wish u all the best... |
10-20-2007, 08:25 | #9 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Kpg Hulu,Sri Aman,SERAWAK
Member: 558761 Status: Offline Thanks Meter: 5 | Assalamualaikum & Goodday, Which ic's for the bluetooth on N430 module?? I want to give it a try to rehot the ic's because i dont have spare on the bluetooth module. regards |
10-20-2007, 15:21 | #12 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Brthr first remove the bluetooth module and then check your phone if it ok then replace bluetooth module.....if it not ok or in white screen without bluetooth module check uem yhe problem in uem.......... |
Help seniors, K310 Show insert Sim after Changed Power IC | madni shah | Sony Ericsson | 1 | 10-22-2009 07:03 |
help with n70 white screen after changing bleutooth ic | gsmspace | Nokia Hardware & Hardware Repair | 5 | 06-25-2008 04:35 |
help for N70 white screen after change sim ic | chronic | Nokia Hardware & Hardware Repair | 1 | 01-22-2008 20:40 |
6600 dead after remov bt ic | DYNET | Nokia Hardware & Hardware Repair | 8 | 06-18-2007 17:19 |
6600 no power after changing hager ic | ashraf_ip | Nokia Hardware & Hardware Repair | 9 | 12-07-2005 14:42 |
