6600 boot error hi all i have 3 nokia 6600 make a defrant error 1- when flash the first one it give me this messege 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w2_st_i.fia, w2_cbusb.fia, Ver: 4.49.0 Alg Boot Error: 2 Error Data1: 00000000: 9F 04 04 00 20 00 C0 88 00 00 21 01 10 00 02 20 .... .....!.... 00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... ..... 00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 FF !.... .....!.... 00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 93 ................ Error Data2: 00000000: F3 72 00 C0 88 00 00 21 01 10 00 02 20 00 C0 88 .r.....!.... ... 00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!.. 00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 FF FF FF FF .. .....!....... 00000030: FF FF FF FF FF FF FF FF FF FF FF FF 93 D3 72 00 ..............r. Before taking screenshot, expand this window ! i chane UEM & upp & flash ic's change flash algorithem manytime from 3.19 to 3.35 the same problem can any one give me some help 2- the secound phone give me this messege 2'nd boot error :2 platform 6 also i change the upp and the same problem ???? 3- the 3'rd phone can't enter to a local mode after flashing i chang UEM & UPP & lash ic's and the small cristall under the batarry socket and the black ic below it ( N380 ) and each time flash the phone is ok but it can't enter to local mode . any help please this cases make me crazy !!!!!!!!! thank for all |
this problem ic bluetooth good luck |
ARe u Some Maintly Upset ? U Changed UEM & Upp & Flash ic's are u mad ? uncheck enable bluetooth flashing uncheck use ini file setting and phone will be oki Solution By Sunnyc WBR Kuku MobileWala Team |
and as i teal befor i use a defrant ini file and the phone is not ok . try to write another solution whithout bad word or don't write any crazy post whithout understanding the case MR. KUKU :mad: |
2'nd i think it is a bad ram and i check for a new one to see the result 3'rd what is the flash n:rolleyes: |
ahhhhhhhhhhhhhh oki oki so when u put out bluetooth module ..is it sure u not much hot on it ? bcoz there very same place pwr ic of the pcb...so very riskey to put out the bluetooth module.. any way ... these are hard errors..not easy to solve WBR Kuku |
and i know ut is a hardware problem that what i ask about so any help to solve it?????? |
try 1st, 2nd ... erase if error occurs at 1st algorithm its the 1st flash Ic and so on and so fort.have tried it once it works |
hii Quote:
your mobile is okk.... |
hi all i have 3 nokia 6600 make a defrant error 1- when flash the first one it give me this messege 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w2_st_i.fia, w2_cbusb.fia, Ver: 4.49.0 Alg Boot Error: 2 Error Data1: 00000000: 9F 04 04 00 20 00 C0 88 00 00 21 01 10 00 02 20 .... .....!.... 00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... ..... 00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 FF !.... .....!.... 00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 93 ................ Error Data2: 00000000: F3 72 00 C0 88 00 00 21 01 10 00 02 20 00 C0 88 .r.....!.... ... 00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!.. 00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 FF FF FF FF .. .....!....... 00000030: FF FF FF FF FF FF FF FF FF FF FF FF 93 D3 72 00 ..............r. Before taking screenshot, expand this window ! wow! looks to me upp problem but you already replce. did you put the upp properly? this kind of error tested by replacing upp or Sdram. last resort trace the lines, maybe line cut |
