Old 01-26-2006, 13:23   #1 (permalink)
Member: 129676
Thanks Meter: 39
6600 boot error
hi all i have 3 nokia 6600 make a defrant error
1- when flash the first one it give me this messege
1st Boot Ok, WD2, UPP: 0082
Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640
Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640
Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640
Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640
Algorithm: w2_st_i.fia, w2_cbusb.fia, Ver: 4.49.0
Alg Boot Error: 2
Error Data1:
00000000: 9F 04 04 00 20 00 C0 88 00 00 21 01 10 00 02 20 .... .....!....
00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... .....
00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 FF !.... .....!....
00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 93 ................
Error Data2:
00000000: F3 72 00 C0 88 00 00 21 01 10 00 02 20 00 C0 88 .r.....!.... ...
00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!..
00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 FF FF FF FF .. .....!.......
00000030: FF FF FF FF FF FF FF FF FF FF FF FF 93 D3 72 00 ..............r.
Before taking screenshot, expand this window !
i chane UEM & upp & flash ic's
change flash algorithem manytime from 3.19 to 3.35 the same problem
can any one give me some help
2- the secound phone give me this messege
2'nd boot error :2
platform 6
also i change the upp and the same problem ????
3- the 3'rd phone can't enter to a local mode after flashing
i chang UEM & UPP & lash ic's and the small cristall under the batarry socket and the black ic below it ( N380 ) and each time flash the phone is ok but it can't enter to local mode .
any help please this cases make me crazy !!!!!!!!!
thank for all
Old 01-27-2006, 07:14   #2 (permalink)
Member: 141422
Alg Boot Error: 2
Error Data1:
Error Data2:
2'nd boot error :2
platform 6
thank for all
1 set u try to flash with lower verson 2 bad ram change it 3 erase flash n after that flash it again hope all work correct
Old 01-27-2006, 14:31   #3 (permalink)
Member: 143156
Thanks Meter: 95
this problem ic bluetooth
good luck
Old 01-27-2006, 14:39   #4 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
ARe u Some Maintly Upset ?
U Changed UEM & Upp & Flash ic's
are u mad ?
uncheck enable bluetooth flashing
uncheck use ini file setting
and phone will be oki
Solution By Sunnyc
WBR
Kuku
MobileWala Team
Old 01-28-2006, 12:26   #5 (permalink)
Member: 129676
Thanks Meter: 39
are u mad ?
Solution By Sunnyc
WBR
Kuku
MobileWala Team
My be you have a problem in your aye or you don't understand what i'am write i alredy flash without bluetooth and i remove the bluetooth module from the phone evry think is the same .
and as i teal befor i use a defrant ini file and the phone is not ok .
try to write another solution whithout bad word or don't write any crazy post whithout understanding the case MR. KUKU
Old 01-28-2006, 12:29   #6 (permalink)
Member: 129676
Thanks Meter: 39
for the firest phone i alredy flash it with a lower version and the same
2'nd i think it is a bad ram and i check for a new one to see the result
3'rd what is the flash n
Old 01-28-2006, 15:41   #7 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
ahhhhhhhhhhhhhh
oki oki
so when u put out bluetooth module ..is it sure u not much hot on it ?
bcoz there very same place pwr ic of the pcb...so very riskey to put out the bluetooth module..
any way ... these are hard errors..not easy to solve
WBR
Kuku
Old 01-28-2006, 19:02   #8 (permalink)
Member: 129676
Thanks Meter: 39
ahhhhhhhhhhhhhh
oki oki
WBR
Kuku
as i toled you befor i chang the power ic (UEM) so there is no denger on it .
and i know ut is a hardware problem that what i ask about
so any help to solve it??????
Old 01-30-2006, 13:33   #9 (permalink)
Member: 223617
try 1st, 2nd ... erase if error occurs at 1st algorithm its the 1st flash Ic and so on and so fort.have tried it once it works
Old 01-30-2006, 16:51   #10 (permalink)
Member: 211283
Thanks Meter: 6
hii
Alg Boot Error: 2
Error Data1:
Error Data2:
2'nd boot error :2
platform 6
thank for all
hiii 1.first upp and flash and than hıgh versiyon for example:6.01
your mobile is okk....
Old 01-31-2006, 07:44   #11 (permalink)
inat's Avatar
Member: 149576
Thanks Meter: 56
Alg Boot Error: 2
Error Data1:
Error Data2:
wow! looks to me upp problem but you already replce. did you put the upp properly? this kind of error tested by replacing upp or Sdram. last resort trace the lines, maybe line cut
6600 1st boot error bad responce from usf!!! nykocam n-Box 11 01-29-2009 15:51
6600 White Screen-first Boot Ok-second Boot Error 2-help zone2 Nokia Hardware & Hardware Repair 2 11-14-2007 15:52
6600 1st boot ok 2nd boot error?? recepoz Nokia Hardware & Hardware Repair 23 08-30-2006 16:58
6600 1st boot error on 2 pieces nykocam n-Box 6 04-14-2005 11:33
nokia 6600 2nd boot error robba WD2 & APE (Symbian Phones) 1 06-08-2004 00:09
Page generated in 0.43028 seconds with 8 queries
