6600 contack the retailer -------------------------------------------------------------------------------- 6600 to throw flash file power on the phone is phone start-up failed.contact the retailer help please thanks |
Format user area. |
hi!!! FORMAT it in phoenix...if formating doesn't work the flash ic is damage and must be replaced in a new one... i r sure u it will work.. @lemor |
Format user area. formating doesn't work the white screen some after 5 minute phone start-up failed.contact the retailer |
flash chip problem...it will ok..r u sure that used phoenix? |
try flash ic after flash with griffin |
yes which flash ic is bad , any one can explain ... |
bad news.. flash ic's is 4 not 3,and the firmware is inside all of them. try the 3650 repair solution |
flashed and full factory reset |
ok.. in hard ware ' ..... contact retailer ' problem. what is the solution ... can you explain .. |
no. i have 5 pcs without to fix any of them.the "6600fullerase fia" is not working with griffin(older versions also). |
:confused: :confused: :confused: |
@gorandj griffin can flash 6600 but phones with "contact retailer" can't format it |
