06-15-2007, 17:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | 6600 dead after remov bt ic |
06-15-2007, 18:22 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | (if not able to make or receive cal) first check 4 any shorting at bt print.....but often there is bad news.....ur UEM ic (glued one) is damaged ...which is on the other side of pcb......reball it if its not damaged or else replace it....hope it works.......luck........do post result......br |
06-16-2007, 07:59 | #7 (permalink) |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | thanks dear i all redy removed bt is right no bt ic on the pcb but my phone boot now any solution for that thanksh 1st Boot Ok, WD2, UPP: 1081 2nd Boot Error: 2 Platform: 6, Error Data: F3 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Process Failed, Repowering Mobile |
06-18-2007, 15:22 | #8 (permalink) |
Freak Poster Join Date: Mar 2006 Location: rajkot (india)
Member: 244357 Status: Offline Thanks Meter: 70 | may be you overheat the mobile, the uem ic is opposite side of bt module. and because overheating any of the ball under uem is damaged the mobile cannot get on. |
6600 dead after changing key pad ic | shok9992000@yah | Nokia Hardware & Hardware Repair | 3 | 04-06-2009 10:25 |
which thing use for clean bord after remove pastted ic | Mohsin-* | Hardware Repair Item Wanted | 6 | 10-30-2008 10:50 |
6600 after chang BT IC, show white LCD | asrar | Nokia Hardware & Hardware Repair | 11 | 10-20-2007 15:21 |
Nokia 6600 dead after removing short BT | zakir375 | Nokia Hardware & Hardware Repair | 1 | 12-12-2006 06:33 |
6600 hang after removing betery conector | m.saif uddin | Nokia Hardware & Hardware Repair | 2 | 12-29-2004 10:42 |
