01-01-2006, 19:11 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Age: 50
Member: 4853 Status: Offline Thanks Meter: 9 | 6600 dead but flash@stop i have nokia 6600 while flashing through ufs3 its shows 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,AA9EAA9E, Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia Algorithm Ok, MSID: 84F1B9FAFBB3840F9295569106 Decoded MSID: 3E4EBAF7-00D616FF-AA000000 Encoded FAID: ED96F44A-739D0E51-0464DB07 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:01 Area2: 0x00010000-0x007FFFFF Erased, Time: 58:53 Area3: 0x04000000-0x046FFFFF Erased, Time: 00:55 Erasing: 0x06000000-0x066FFFFF ... Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile and i changed compleate 4 flash ic amd now it shows like this 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x067FFFFF,FFFFFFFF, Algorithm: w3_amd.fia, w3_cbusb.fia Algorithm Ok, MSID: 84F1B9FAFBB3840F9295569106 Decoded MSID: 3E4EBAF7-00D616FF-AA000000 Encoded FAID: ED96F44A-739D0E51-0464DB07 Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 01:21 Area: 0x04000000-0x046FFFFF Erased, Time: 01:06 Erasing: 0x06000000-0x066FFFFF ... Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile can any one help please |
01-01-2006, 21:08 | #3 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: india
Member: 84807 Status: Offline Thanks Meter: 67 | Quote:
Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,AA9EAA9E, reball it if it show then flash it otherwise change it | |
01-02-2006, 06:36 | #4 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Colombo, Sri Lanka Age: 55
Member: 58172 Status: Offline Thanks Meter: 13 | Use FULL ERASE first and then write the flash and update PM, Unlock and Format USER Area. After full erase the MCU & PPM should write if not try to give manual ignition or press the switch right throuh the process. WBR |
01-02-2006, 19:35 | #6 (permalink) |
Member: 4853 Status: Offline Thanks Meter: 9 | respected members i changed four flash ics with different manf like st to amd now its shows 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x067FFFFF,FFFFFFFF, Algorithm: w3_amd.fia, w3_cbusb.fia Algorithm Ok, MSID: 84F1B9FAFBB3840F9295569106 Decoded MSID: 3E4EBAF7-00D616FF-AA000000 Encoded FAID: ED96F44A-739D0E51-0464DB07 Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 01:21 Area: 0x04000000-0x046FFFFF Erased, Time: 01:06 Erasing: 0x06000000-0x066FFFFF ... Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile so perticularly i changed fl13 then its shows like this 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x06FFFFFF,0020FFFF,St No Name Algorithm: w3_amd.fia, w3_cbusb.fia Algorithm Ok, MSID: 84F1B9FAFBB3840F9295569106 Decoded MSID: 3E4EBAF7-00D616FF-AA000000 Encoded FAID: ED96F44A-739D0E51-0464DB07 Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 01:20 Area: 0x04000000-0x046FFFFF Erased, Time: 00:05 Erasing: 0x06000000-0x066FFFFF ... Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile |
01-06-2006, 18:53 | #7 (permalink) |
Freak Poster Join Date: Jan 2006 Location: mars under soft & hardware....
Member: 217604 Status: Offline Thanks Meter: 12 | [quote=sivaprasad]respected members i changed four flash ics with different manf like st to amd now its shows 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x067FFFFF,FFFFFFFF, Algorithm: w3_amd.fia, w3_cbusb.fia Algorithm Ok, MSID: 84F1B9FAFBB3840F9295569106 Decoded MSID: 3E4EBAF7-00D616FF-AA000000 Encoded FAID: ED96F44A-739D0E51-0464DB07 Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 01:21 Area: 0x04000000-0x046FFFFF Erased, Time: 01:06 Erasing: 0x06000000-0x066FFFFF ... Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile so perticularly i changed fl13 then its shows like this 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x06FFFFFF,0020FFFF,St No Name Algorithm: w3_amd.fia, w3_cbusb.fia Algorithm Ok, MSID: 84F1B9FAFBB3840F9295569106 Decoded MSID: 3E4EBAF7-00D616FF-AA000000 Encoded FAID: ED96F44A-739D0E51-0464DB07 Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 01:20 Area: 0x04000000-0x046FFFFF Erased, Time: 00:05 Erasing: 0x06000000-0x066FFFFF ... Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile[/quote disable bt flashing and flash your phone sometimes the blue tooth chip makes this so if you skip it,it will flash.regards. |
01-07-2006, 07:55 | #8 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: Malaysia Age: 43
Member: 202941 Status: Offline Thanks Meter: 85 | Quote:
01-09-2006, 05:11 | #9 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 51061 Status: Offline Thanks Meter: 1 | i have same problem,comfirm nothing to do with flashing and ic problem. unlees got correct solution otherwise don teach people the wrong way,to this and that.Thanks for you help!! |
01-10-2006, 20:24 | #10 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
01-10-2006, 20:51 | #11 (permalink) |
Member: 217604 Status: Offline Thanks Meter: 12 | "Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile" with the latest software of ufsx software 1.4d means unknown flash.so if you are using that very software,you should now that it doesnt show unknown flash but only that. |
01-10-2006, 21:20 | #13 (permalink) | |
Member: 217604 Status: Offline Thanks Meter: 12 | " Quote:
with the new ufsx software 1.4d,unknown flash is seen as erase error | |
01-10-2006, 21:22 | #14 (permalink) |
Member: 217604 Status: Offline Thanks Meter: 12 | try any phone if you have any unknown flash and then you will know what i mean."Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile" is what you will see on your screan. |
