03-03-2005, 13:16 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Portugal Age: 51
Member: 90668 Status: Offline Thanks Meter: 57 | 6600 doens´t stay on ? I have a Nokia 6600 that doesn´t stay on. When I press power th light turns on but 2 seconds later the phone goes off. - Battery is fully charged. - I've flashed it with Prodigy. - I've flashed it with Twister. - Software version 5.27 - Flash goes ok, but at the end the machines can't power phone on. - as I connect it to Prodigy, there should be a "NOKIA" on-screen, it appears but disapears right away and then shows up again, and keeps going on and off. If anyone could help... I appreciate ! Many Thanks |
03-03-2005, 17:14 | #2 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | 1. try to search forum, u will find the solution 2. make FLASH ERASE using twister, when booting phone look good which memory adresses+ranges are active (6600) has 4x flash IC and erase whole flash IC by entering range (ranges) in to flash erase dialog. After that flash it again with 5.27, uploat good MP, make user area format and Unlock. phone should work.. Post |
03-03-2005, 17:19 | #3 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 41
Member: 90734 Status: Offline Thanks Meter: 3 | 6600 problem You are right Yoda_Brno. I got some of this type before, and it repaired it with user area format. Have you tried this Mr. Futuro???? Twister is good for Nokia phones. Sweden Mobile |
03-03-2005, 18:49 | #4 (permalink) |
Member: 90668 Status: Offline Thanks Meter: 57 | Hy, I've tryed all U have sugested. I've erased PM and tryed to flash again with good PM but phone doesn't stay powered for enough time. The phone power lasts about 2 seconds. With Twister and with Prodigy is always the same problem. PM flashing takes about 4 seconds, but flash always stops in the middle because phone powers off! I think it is hardware problem! |
03-03-2005, 18:55 | #5 (permalink) | |
Member: 40423 Status: Offline Thanks Meter: 5 | Quote:
03-03-2005, 18:56 | #6 (permalink) | |
Do not solder anything..u have to be 100% sure that u made everyting possible via cable.. Only then start soldering.. BTW flash IC defect u will recognize only when u try to erase it all (from its start range to end range) when erasin only with flashing there is not erased everything.. ERASE EVERY SINGLE CHIP | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
6600 doens´t stay on ? | Futuro | Federal One | 1 | 03-04-2005 22:52 |
MARS problem,stays ON only when i dont remove finger from POWER button | crossings | Hardware Repair by brands | 4 | 02-21-2003 03:24 |
Samsung N100 Stays on just if on button is down! | .::AkhavanGSM::. | Samsung Hardware Repair | 4 | 11-04-2002 09:13 |
8210 dont stay on | anry | Nokia Hardware & Hardware Repair | 6 | 08-21-2002 15:43 |
