06-25-2006, 08:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: sri lanka
Member: 230371 Status: Offline Sonork: 100.1614924 Thanks Meter: 52 | can convert 8390 >8310 , 900/1800mz ? 8390 > 8310 , 900/1800mz...... thanks.. [email protected] |
06-25-2006, 15:34 | #3 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 51
Member: 78767 Status: Offline Sonork: 100.95137 Thanks Meter: 566 | 8390 to 8310 Convert 8390 to 8310 1. Jumper resistor is a resistor (not actually a resistor) with 0 ohm value, usually colored green with 0 markings. Wire can also be use instead, but must not be very thin and should be as short as possible. Thin and long wire will introduce high inductive reactance and will result to weak received signal. 2. T500 can be taken from 3310 unit. It is located just above HAGAR, refer to your service manual to easily locate it. Also take note to its pin orientation during installation. Bypassing Z551 with wires is not recommended,this will weaken the receiver sensitivity due to incorrect signal phase relationship. 3. Give special attention when installing VCO, improper positioning will result to no network activity |
Converting 1100b-rh36 850/950Mz To 1100-rh18 900/1800Mz | ssatcom | Nokia Repair Guide and FAQ | 137 | 01-23-2013 18:40 |
Is it possible to convert 3300 to 900 MHz??? | RafalTK | Nokia Hardware & Hardware Repair | 0 | 05-27-2005 20:03 |
Can we convert A56 to 900/1800mhz | mobileclinic | Siemens Hardware Repair Area | 2 | 03-27-2005 14:11 |
Converting c350 850/950Mz(canda and usa) To c350 900/1800Mz | shadi | Motorola P2k | 0 | 01-23-2005 12:36 |
Is it possible 8390->8310? | The Racer | Nokia Hardware & Hardware Repair | 10 | 04-16-2004 10:29 |
