01-19-2005, 08:18 | #17 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | Only solutio is to replace this part and unless you have some very special equipment, you cannot reball this chip because of the size, (Very small). replace new one and solution solve 100% BR |
01-21-2005, 16:16 | #18 (permalink) |
Junior Member Join Date: Dec 2004
Member: 95872 Status: Offline Thanks Meter: 0 | To everyone who's wondering where the 2 chips are: Open the phone. You will see the keypad is connected to the phone board through a connector. On the left side of the connector you will see 2 small square BGA chips. If some of your keys are not working and you have already tried the keypad itself and you don't find a problem there, then try these chips. If one of the chips is chipped or broken you don't have to look for the problem anywhere else. First try to reflow the chips. If that doesn't work then take the chips from another phone, reball them, using a mask and solder them on the phone to be repaired. The 2 chips are controlling different keys, so if you are lucky you will do it only by replacing one chip. Test the phone after each replacement and take notes of which keys are working. If after replacement the condition of the phone is worse then you haven't soldered the chip properly. Good Luck! |
01-25-2005, 12:27 | #20 (permalink) |
No Life Poster Join Date: Jul 2003 Location: BahaMAS Age: 40
Member: 35975 Status: Offline Thanks Meter: 19 | Thanks for the info barak. As we can see in the pdf it is used for protection and as a filter only. So if we find input and outputs of chip, then we can put short and see what happens. Anyone can help me find these please? tonytony |
01-25-2005, 12:58 | #21 (permalink) |
Member: 35975 Status: Offline Thanks Meter: 19 | Visit this link for a detailed account of this ic. http://www.st.com/stonline/press/mag...i99/pnews1.htm But we still need pinouts to perform any repair.. thanks tonytony |
01-25-2005, 20:49 | #22 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | soln for keypads Quote:
Nokia 6600 keypad problem | vali.rusu | Nokia Hardware & Hardware Repair | 5 | 08-30-2010 23:34 |
6600 keypad problem | ..::Sunil::.. | Nokia Hardware & Hardware Repair | 7 | 10-10-2007 21:00 |
6600 keypad problem strange | kprajeesh4u | Nokia Hardware & Hardware Repair | 10 | 09-23-2007 08:00 |
6600 keypad problem | rvnl_adrian | WD2 & APE (Symbian Phones) | 0 | 01-08-2007 08:55 |
6600 Keypad problem | Cloud-Strife | Nokia Hardware & Hardware Repair | 2 | 12-16-2005 05:23 |
