06-16-2004, 14:30 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | 6600 keypad problem rehot upp but no help . I need assistance please. [email protected] |
06-17-2004, 18:30 | #4 (permalink) |
Insane Poster Join Date: Sep 2002 Location: South Africa
Member: 15928 Status: Offline Thanks Meter: 0 | Hi Keke, I have the same problem. After the phone dropped keys 2,5,8 won't work. There are 2 small black chips in the bottom area of the pcb. I believe that this could be the problem because one of the chips seems to be chiped on the edge...? Sorry, I dont have their names....still looking for schematics! Regards AFR |
12-08-2004, 16:34 | #11 (permalink) |
Junior Member Join Date: Dec 2004
Member: 95872 Status: Offline Thanks Meter: 0 | ok guys, the problem is really in the two BGA chips near the keypad connector. I was able to fix many of these whenever I had another 6600 to use as a donor. They are protection ICs similar to the one in 8310 near the sim connector. In 8310 we are able to take the chip off and put 3 shortcuts on the pins. Here it should be the same. The question is: what is the shcematic? |
01-17-2005, 15:35 | #14 (permalink) |
No Life Poster Join Date: Jul 2003 Location: BahaMAS Age: 40
Member: 35975 Status: Offline Thanks Meter: 19 | WHAT DO YOU MEAN BY ( try the litlle crystal under the keypad connector it works 100%??? HEAT IT, REMOVE IT, OR REPLACE IT?? DOES ANY HAVE SCHEMATIC TO PUT 3 SHORTS INSTEAD OF REPLACING SINCE NEW FILTER IS NOT AVAILABLE!! TONYTONY |
Nokia 6600 keypad problem | vali.rusu | Nokia Hardware & Hardware Repair | 5 | 08-30-2010 23:34 |
6600 keypad problem | ..::Sunil::.. | Nokia Hardware & Hardware Repair | 7 | 10-10-2007 21:00 |
6600 keypad problem strange | kprajeesh4u | Nokia Hardware & Hardware Repair | 10 | 09-23-2007 08:00 |
6600 keypad problem | rvnl_adrian | WD2 & APE (Symbian Phones) | 0 | 01-08-2007 08:55 |
6600 Keypad problem | Cloud-Strife | Nokia Hardware & Hardware Repair | 2 | 12-16-2005 05:23 |
