10-17-2007, 21:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::problemz with 6030::.. |
11-05-2007, 15:52 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | 6030 flash complit with faf but not power.any solution plz.... here is the log MCU ID: 0x2031 FLASH ID0: 00012C7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.00 Done! Phone Restarted... Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... MCU ID: 0x2031 Reading flash chip detailes... FLASH ID0: 00012C7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2031 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.11a CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.11.image_a ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic MCU: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.110 Booting phone... MCU ID: 0x2031 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.40.00 -> Revision: 0007 Boot size is 0x0970 Boot is ready... FLASH ID0: 00012C7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x7E2C0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.40.00 -> Revision: 0007 Loader size is 0x7010; Loader chk: 94 Loader is ready... P-key nokia module version 01.00 MSID: 8444EBF25C588604A3740B9102 MSID decoded: 00F4BAE900DA1CE3A8000000 FAID: 0BF2FF23472B6958FC8F68CA Operation took 0 minutes 16 seconds... Erasing... Found 3 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 017BFFFF... Erasing area: 01F20000 - 01FDFFFF... Operation took 0 minutes 58 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 33 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.11.image_a Booting phone... MCU ID: 0x2031 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.40.00 -> Revision: 0007 Boot size is 0x0970 Boot is ready... FLASH ID0: 00012C7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2C0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.40.00 -> Revision: 0007 Loader size is 0x7010; Loader chk: 94 Loader is ready... P-key nokia module version 01.00 MSID: 8482FB3E6CB8D6005636B3FBAD MSID decoded: 1C15BAE300DA1CE3AD0005BD FAID: 5DF03BB94EC7A43E17A9DCBD Operation took 0 minutes 16 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01C00000 - 01F1FFFF... Operation took 0 minutes 21 seconds... Writing... Writing converted flash to 128k page Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.11a Booting phone... MCU ID: 0x2031 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.40.00 -> Revision: 0007 Boot size is 0x0970 Boot is ready... FLASH ID0: 00012C7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2C0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.40.00 -> Revision: 0007 Loader size is 0x7010; Loader chk: 74 Loader is ready... P-key nokia module version 01.00 MSID: 841580E9A497BB4EBF97981F15 MSID decoded: 3E4EBAE900DA1CE3A9000000 FAID: 75DC611E663563C6C8B6FFD8 Operation took 0 minutes 16 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 017C0000 - 01BFFFFF... Operation took 0 minutes 29 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 18 seconds... Restarting MCU... Flashing Done! Operation took 5 minutes 17 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! |
11-08-2007, 13:37 | #5 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | Quote:
11-08-2007, 21:09 | #6 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | Hi hum, in that case I will handle with ufs if mcu flashing done ppm flashing done but no result in that time I change ppm file and select flash only ppm and I get always good result.....now another think one more time rehot upp and little seeking that’s all…good luck |
5230 boot display SIM card invalid ATF success with good repair! | 20442044 | Advance-Box | 3 | 06-09-2015 08:56 |
new zong with tourch can,t be unlock | pakmobiles | FuriousGold | 3 | 03-29-2010 16:26 |
..::can we use 1100 or 2300 flash ic in 6030::.. | HUM | Nokia Hardware & Hardware Repair | 7 | 10-09-2007 10:17 |
