Old 12-13-2004, 21:53   #1 (permalink)
MELME's Avatar
Member: 18974
Thanks Meter: 2
6600 no open gallary and bt no work plz help
see what i do and waht should i do
i recived the mobile no power
i tried to flash the phone with ufs3 i get this massage
1st Boot Ok, WD2, UPP: 0082
Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT
Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT
Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT
Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT
Algorithm: w2_amd.fia, w2_cbusb.fia
Algorithm Ok, MSID: 841E27680CD9010E8BE7DB7EA8
Decoded MSID: 3E4EBAF7-001A75D7-A8000000
Encoded FAID: F1387041-D2B09EB8-C93F8AF1
Cbus Boot Error: 9
Error Data1:
00000000: 00 96 84 1E 27 68 0C D9 01 0E 8B E7 DB 7E A8 67 ....'h.......~.g
00000010: 26 02 26 10 01 04 01 00 7E 26 02 26 10 01 06 01 &.&.....~&.&....
00000020: 00 7E 26 02 26 10 01 C6 00 00 EA 75 01 00 EA 78 .~&.&......u...x
00000030: 01 00 EA 7B 01 00 EA 9A 00 00 00 00 00 00 00 00 ...{............
Error Data2:
00000000: A3 72 72 7E 26 02 26 10 01 02 01 00 7E 26 02 26 .rr~&.&.....~&.&
00000010: 10 01 04 01 00 7E 26 02 26 10 01 06 01 00 7E 26 .....~&.&.....~&
00000020: 02 26 10 01 C6 00 00 EA 75 01 00 EA 78 01 00 EA .&......u...x...
00000030: 7B 01 00 EA 9A C3 72 00 00 00 00 00 00 00 00 00 {.....r.........
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
i remove the bt flashing and flash mobile flashing and open but gallary stop in opening files take 1 minite and give me a masssage "app. closed screensaver" or "app.close media gallary "and bt not work but camera work ok and saving when i tried to open gallary from the camera same massages come "app.close media gallary "
i erasse holl flash by eraser files and addresses and try to flash with ufs same error come
Cbus Boot Error: 9
Error Data1:
with griffin
Initializing Phone...
Flash configuration:
9B040001007E26022610010201007E26...
Error[BDBDADAD]
if i skip bt flashing ok
before any mobile no oen gallary i change flash no. 2 from the left and uem also
i do but come same
i change bt kit "the hole ic's" come same no bt flashing
i chane the 4 flashes come same
i tried softwear
i erase hole flash then write pm without product code same also
what i can do else
thanx
regards
MelMe
Old 12-14-2004, 21:58   #2 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Ur problem is about software i think u can try to format the phone without any box only with phone .
Br Ionel.
Old 12-15-2004, 18:02   #3 (permalink)
Member: 1060
Thanks Meter: 10
key is there already show to you : "Cbus Boot Error: 9"
check it diagram, then you can see, it between UEM to UPP to BT !
Willy
Old 12-16-2004, 07:48   #4 (permalink)
Member: 60729
using erase file. i'll be ok
Old 12-16-2004, 11:23   #5 (permalink)
hanen's Avatar
Member: 70053
Thanks Meter: 85
basha
u must flash phone with skip BTflash after u flash phone with
enabale bt flashing with speed normal
i thank u phone is ok
good l
Old 12-17-2004, 12:48   #6 (permalink)
MELME's Avatar
Member: 18974
Thanks Meter: 2
thanx mr.willy fixed
inside NOKIA phone
Old 01-05-2005, 18:30   #7 (permalink)
Member: 86567
Same Problem
Can you explain exactly how to do it, becouse I don't understand.
Sorry
Thanx
Old 01-07-2005, 03:19   #8 (permalink)
mobile star's Avatar
Member: 54916
Thanks Meter: 58
i have the same problem cant open gallery and bluetooth not work
but the the phone take softwar and full erase normaly can u tell us how u fix ur problem MELME
OR willy can post pic to this line
Old 01-07-2005, 05:58   #9 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
CBus error
Look at this - i ve faced the same error last night. i m attaching screenshot. Phone was having problem of no access to "GALLERY".
THen i tried hongkong c3 file. BUT now phone turns ON - BUT white screen. Even no "NOKIA" on screen - It doesnt go into LOCAL MODE !
Old 01-07-2005, 06:25   #10 (permalink)
sudeeshveekey's Avatar
Member: 18837
Sonork: 100.1601544
Thanks Meter: 71
some one can explain how to fix this problem? MELME please explain this if u can..
Old 01-12-2005, 09:57   #11 (permalink)
Registered User
Member: 38417
Thanks Meter: 2
thanx mr.willy good work
Old 01-15-2005, 11:38   #12 (permalink)
MELME's Avatar
Member: 18974
Thanks Meter: 2
sorry i was out for few days
fix the problem by changing the bt ic with good one from 6600 not 6310
this fix the problem
Old 03-04-2005, 17:36   #13 (permalink)
kasra's Avatar
Member: 103435
Thanks Meter: 49
can anyone explain me how can i fix this problem plz?
Old 03-04-2005, 19:14   #14 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
Mr. Willy U r super mod. so u should share the secreats with all the persons in this forum, this is not a private place, we also want to know what solution u have given to MELME
Old 03-04-2005, 23:43   #15 (permalink)
kasra's Avatar
Member: 103435
Thanks Meter: 49
yah if its free and u can share it with us plz do this
1202 only open speaker work....plz help guljee786 Nokia Hardware & Hardware Repair 5 05-02-2010 07:50
v3 ringer and speaker not working plz help asif_ae Motorola Hardware Repair 1 06-26-2009 12:37
w810i speaker and buzzer don't work,plz help!!! gsmshare98 Sony Ericsson Hardware Repair 1 01-29-2008 12:04
6280 camera problem (operation failed) and Bt don't work .:bono:. Nokia Base Band 5 ( BB-5 ) 5 07-13-2006 08:09
6600 no open gallary and bt no work plz help MELME UFS2 + UFS3-Tornadoflasher 7 12-15-2004 02:05
Page generated in 0.28803 seconds with 10 queries
