Old 07-07-2007, 07:03   #1 (permalink)
Member: 403881
Thanks Meter: 80
6600 not booting after flashing
Hi, to all
My 6600 flashing completed at end of flashing it should BOOT but it is not doing so plz see log.
JAF version 1.98.23
Detected PKEY: 9000734C
Card life counter: 94.93%
P-key nokia module version 01.00
Detected JAF INTERFACE version: 01.AC, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: D:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: D:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: D:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: D:\Program Files\ODEON\JAF\Flash3\
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: D:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1
PPM Flash file: D:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.A3
Languages in ppm: O2,IRELAND
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: D:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1
Booting phone...
MCU ID: 0x1081
BOOT file: D:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Loader version: 04.3D.00 -> Revision: 0007
Boot size is 0x1090
Boot is ready...
FLASH ID0: 2000C088 -> SEC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 2000C088 -> SEC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 2000C088 -> SEC Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 2000C088 -> SEC Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Flash ID is 0x88C00020
Flash loader is D:\Program Files\ODEON\JAF\Flash\w3_st_i.fia
Loader size is 0x57F8; Loader chk: 1b
Loader is ready...
MSID: 8416F960716A8C6504DD6758D3
MSID decoded: 3E4EBAF700DCE0CDA9000000
FAID: D51376435EE17386D6FA73A7
Flash loader is D:\Program Files\ODEON\JAF\Flash\w3_cbusb.fia
Loader size is 0x2020; Loader chk: 2c
Additional Loader is ready...
Operation took 0 minutes 23 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 007FFFFF...
Erasing area: 04000000 - 046FFFFF...
Erasing area: 06000000 - 066FFFFF...
Erasing area: 047C0000 - 047EFFFF...
Operation took 2 minutes 59 seconds...
Writing...
MCM Register OK
Perm. Data Restore OK
Operation took 2 minutes 31 seconds...
Restarting MCU...
PPM: D:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.A3
Booting phone...
MCU ID: 0x1081
Boot size is 0x1090
Boot is ready...
Loader is ready...
Operation took 0 minutes 20 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 02000000 - 0214FFFF...
Operation took 0 minutes 11 seconds...
Writing...
Operation took 0 minutes 8 seconds...
Restarting MCU...
Flashing Done!
Operation took 7 minutes 5 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Waiting valuable suggestion of all members.
Old 07-07-2007, 10:25   #2 (permalink)
markrhi's Avatar
Member: 520956
Thanks Meter: 12
bro, you need to use other box..or upgrade the software version..try5.53
Old 07-07-2007, 10:36   #3 (permalink)
HAROON's's Avatar
Member: 100592
Sonork: 1578498
Thanks Meter: 245
markrhi
see care fully he is already using
try to full erase and then conplete flash it again
best of luck
Best Regards
GSMCrazy1
Old 07-07-2007, 11:46   #4 (permalink)
kanwal's Avatar
Member: 496736
Thanks Meter: 17
u need proper flashing file to work .latest flash file down load and it will work
Old 07-07-2007, 12:49   #5 (permalink)
Member: 530066
that is Hardware problem bro, try to replace zocus near battery conector, that is curent sensor and make phone boot fail when it weakness
Old 07-07-2007, 13:51   #6 (permalink)
Member: 403881
Thanks Meter: 80
Thanks to all i will post result after applying solution.
Old 07-08-2007, 09:48   #7 (permalink)
Member: 403881
Thanks Meter: 80
I CHANGED ZOCUS BUT PROLEM IS SAME
Old 07-11-2007, 00:00   #8 (permalink)
Member: 162698
Originally Posted by GSMCrazy1 View Post
markrhi
best of luck
Best Regards
GSMCrazy1
Pls, does it mean the files selection below is incorrect? Pls, tell me the correct file sellection.
cheers
markrhi
Old 07-11-2007, 02:51   #9 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
Originally Posted by sarojrkl View Post
Hi, to all
JAF version 1.98.23
Failed! Aborting!
Booting phone...
MCU ID: 0x1081
Boot size is 0x1090
Boot is ready...
Loader is ready...
Erasing...
Writing...
MCM Register OK
Restarting MCU...
Booting phone...
MCU ID: 0x1081
Boot size is 0x1090
Boot is ready...
Loader is ready...
Erasing PPM...
Writing...
Restarting MCU...
Flashing Done!
Failed! Aborting!
CHECK what PPM have you put.you put a MCU file in PPM area.
br
keaelite
Old 07-11-2007, 05:57   #10 (permalink)
Member: 403881
Thanks Meter: 80
br
keaelite
I am sorry if i am wrong, As per my knowledge i have put proper files plz see once again.
Any way thanks for your suggestion if any thing wrong plz let me know.
Old 07-14-2007, 10:24   #11 (permalink)
Member: 530066
let's look your problem, u mean that phone can't display anything, and no respon after boot, or it just can show NOKIA letter'e, but not respons after a long time...., if there is blank display and no respons, try to replace UEM, if u see NOKIA, just full erase flash, and flashing again
BB 8310 not booting after flashing firmware dpi295 BlackBerry (RIM) 3 12-26-2008 12:50
1650 not booting after flashing sarojrkl Nokia Hardware & Hardware Repair 26 08-05-2008 10:49
6600 Not Booting at the End of Flashing sarojrkl Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-07-2007 20:26
6630 not booting after flashing muyinetsystem Nokia Base Band 5 ( BB-5 ) 3 01-02-2006 22:17
C650 Not booting after flash nedim76 Motorola P2k 10 11-21-2004 14:59
Page generated in 0.24685 seconds with 9 queries
