10-07-2005, 13:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: UKRAINE Age: 46
Member: 22400 Status: Offline Thanks Meter: 44 | 6600 Power On And Jammed I have nokia 6600 with strange problem This phone start-up when on LCD i see -NOKIA- and all! Phone jammed and not blinking not off backlight LCD (olways on) I reflash phone all possible way's I change CPU RAM FLASH UEM phone not work !!!! what is it if you have info please answer me.... BEST REGARD CHIP_2000 |
10-08-2005, 14:16 | #4 (permalink) | |
Member: 22400 Status: Offline Thanks Meter: 44 | Quote:
flash reflash erase - not work | |
03-26-2006, 23:14 | #11 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: pakistan
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan Quote:
CHECK MY THREAD http://forum.gsmhosting.com/vbb/show...=271729&page=3 STEP1: Remove battery and Connect cable in your phone and full erase flash with this file (6600_fullerase.fia) download file URL link : http://70.85.181.19/ufsx/download.php?id_file=3179 STEP2: FULL FLASH MCU,PPM,PMM CHOOSE THE NORMAL SPEED PRESS "START" BUTTON DO THE JOB . NOTE: WD2 PHONE BOOTING IS SLOW ,SO PLEASE BE PATIENT HERE, AND DON'T DO THESE STEPS FAST. STEP3: When flashing is done,choose "Normal" in UI Setting ,after that can see the "Init Normal Mode OK in the software STEP4:Choose "Local" in UI Setting, after that can see the "Init Local Mode OK" in the software STEP5:Press the "format user area" Button, after that can see the "User Area Format OK" in the software. step6:[SIZE=2] Done IF PHONE DOESN'T ENTER "LOCAL" MODE WHEN CONNECTED OR AFTER FLASHING. PLEASE CHECK CABLE WITH SCHEEMATICS (BSI WIRE) HERE MUST BE SERIAL RESISTOR ON BSI (3.3KOM) And also check power swicth also power swicth way's be sure is good and working proper, check filter, capaciter , daivode arround the power swicth , CHECK THIS. AND REPLY FAST RESULT. I M WAITING YOUR RESULT. Best Regard, tommobil2004GSM CO,LTD Last edited by ..::Neo::..; 04-02-2006 at 22:59. | |
03-26-2006, 23:23 | #12 (permalink) |
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan HELLO, chip_2000 HERE IM ATTACH 6600_fullerase DOWNLOAD AND WORK ' hope you'll success If a problem occure to contact us, BEST REGARD, Last edited by ..::Neo::..; 04-02-2006 at 23:00. |
03-26-2006, 23:28 | #13 (permalink) |
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan chip_2000 DO THIS JOB I HOPE YOU WILL SUCCESS IF PROBLEM SAME AND STILL CONTACT ME AND INFORME THE RESULT YOU CAN CONTACT ME EVERY TIME ENJOY BEST REGARD, Last edited by ..::Neo::..; 04-02-2006 at 22:58. |
03-27-2006, 10:06 | #14 (permalink) |
Junior Member Join Date: Oct 2004 Age: 50
Member: 85822 Status: Offline Thanks Meter: 0 | Repair _ Mobile hello my dear ... the solve to your problem is :- 1- this problem in flash Ic 100% . 2- Rehot On this Flash And Reflash mobile if work ok yes if not .. 3- read pm file from ur mobile and convert it to rpl file ... then 4- Replace 4 Flash Ic With A new orginial and the same type then .. 5- refalsh phone after replace ic then write rpl file and calculate ... 6- then open the phone if work ok if not ... 7- replace UEM ic then write any rpl file ... 8- then open the phone its work thats all if u need more help chat me on my yahoo massenger newmazin2003 in night ok ... bay |
Nokia 6600 power on white LCD only (water damage) *mostly solution* | mobilagy | Nokia Hardware & Hardware Repair | 11 | 12-25-2007 20:23 |
6600 power on problem | SATISH | Nokia Hardware & Hardware Repair | 5 | 08-12-2006 09:26 |
6600 powering on by itself when battrey is inserted.... switch has no effect at all | Burnt Cobba | Nokia Hardware & Hardware Repair | 4 | 04-11-2005 19:51 |
6600 Power On/Off | Rahuman28 | WD2 & APE (Symbian Phones) | 1 | 04-01-2005 18:56 |
6600 Power On/Off | Rahuman28 | Griffin | 2 | 03-21-2005 10:49 |
