Old 12-09-2007, 17:44   #1 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
6600 problem with batterie
hi
i got a nokia 6600 has problem with any batteri using in it
i mean i put a fully charged & original batt, but doesn't worth more than 4 hours, after and battrie goes empty quiquely, i tested 3 deffrents battries .
any solution pleaz ?
thankx
Old 12-09-2007, 19:38   #2 (permalink)
Member: 470292
Thanks Meter: 147
Clean your pcb with ctc well. Then give light heat. I mean dry it. Then Resold batery connector and the points of batery connector and batery should be clean and tidly connected. Your problem will be soloved. If not then resold PA. and enjoy....
Old 12-11-2007, 06:09   #3 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
Originally Posted by fethi View Post
hi
thankx
try this 4 6600 bat problem
Sony Ericsson T610 problems, no charge, not a problem with battery or adapter ultrajosh Sony Ericsson Hardware Repair 2 12-10-2008 12:46
Problems with Battery Connector Christobol_007 DreamBox 2 06-15-2006 01:23
problems with battery after flashing sakhin x1x to x45/x50 3 12-09-2002 10:16
Problem with battery indicator on 3210 cole Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-19-2002 04:03
problem with battery mrENigma Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 10-10-2001 18:18
Page generated in 0.15519 seconds with 10 queries
