09-16-2004, 12:07 | #1 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Thessaloniki,Hellas Age: 44
Member: 33547 Status: Offline Thanks Meter: 17 | 6600 R230 broken The phone is completely dead, is it because of this resistor? I can't flash it also. Can i replace them with anything else? Thank you |
09-16-2004, 20:28 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Well ... R230 is a quadrizinner with common Ground , ths device is for protection of data bus (Fbus-Mbus) from over voltage and from electrostatic charges , it could be shorted from inside or from the point of crack ( could be shorted to Grnd ) . If U totally removes it the phone will not affect at all , try it and dont be wary Good Luck Bro. |
09-17-2004, 08:33 | #3 (permalink) |
Member: 33547 Status: Offline Thanks Meter: 17 | I tryed to flash it bwith Griffin but i get result 444900 (no connection with phone i think) So i'll try to remove it and reflash it I'll post the results. Thank you Medz |
09-20-2004, 22:05 | #5 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | I searched on the forum ( error 44449000 ) , it telles that it is no cable as U sayes , So if U dont know the cuse of the problem , I suppose that it could be an over voltage comes to the cable !!. If that is the problem , it will be a big problem cause we dont know whats else beside the UPP may be affected , we may take a long trip but invaine. I dont know from where to start but if U can , lets replace the UPP ? |
nokia 6600 bluettoth circuit broken | daltontech_ph | Nokia Hardware & Hardware Repair | 6 | 02-24-2009 18:21 |
6600 power switch ways broken | khan_mobiles | Nokia Hardware & Hardware Repair | 3 | 11-25-2008 14:10 |
6600 keypad Glass Ic Broken, Pls Help!!!!! | kaino147 | Nokia Hardware & Hardware Repair | 21 | 02-15-2008 13:42 |
6600 Broken Display | bugztronic | WD2 & APE (Symbian Phones) | 2 | 06-16-2007 03:14 |
Nokia 6600 broken button-help pls | dre000 | Nokia Hardware & Hardware Repair | 2 | 03-19-2006 12:52 |
