09-11-2007, 18:16 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Bali - Denpasar
Member: 526402 Status: Offline Thanks Meter: 8 | 6600 UI and FullFactory I Have problem with my fone, flash with Tornado, All procedure OK, but in UI Setting and set Full Factory ONLY Always problem / failed. Rehat IC Flash and RAM still FAILED What can i do for best solution for this fone Thq and Sukron. |
09-12-2007, 03:20 | #5 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 562532 Status: Offline Thanks Meter: 10 | use ufs+hwk.. erase all flash first,. den unchek BT flashing.. flash phne..after flsh complete, format user area., full factory defaults, write gud pm, init simlock.. Good luck bro. BR SIOUX |
09-14-2007, 05:40 | #8 (permalink) |
Temporary banned !! Join Date: Jul 2007 Location: Toketek Age: 44
Member: 546766 Status: Offline Thanks Meter: 51 | follow this step full erase full flash just info many times formate your phone and use 3 option 1.rebhoot in normal mode init sim locks reset user lock |
09-14-2007, 09:18 | #9 (permalink) | |
No Life Poster Join Date: Jul 2006
Member: 319612 Status: Offline Thanks Meter: 1,452 | Quote:
just do info many times untill it reads phone fully, then you can perform UI options | |
09-14-2007, 17:44 | #10 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: pok wong malaysia
Member: 300886 Status: Offline Thanks Meter: 61 | Quote:
b.r kindo | |
6600 ui setting failed | ajitsnit | WD2 & APE (Symbian Phones) | 2 | 02-13-2009 09:27 |
6600 Ui Setting Filed | ameho0102 | Nokia Hardware & Hardware Repair | 23 | 05-21-2008 12:42 |
6600 Ui Settinng Fialed | tausyef | WD2 & APE (Symbian Phones) | 1 | 08-01-2007 10:44 |
UBTEAM i flashed N6630 with other pm and fullfactory | gsm8g | Universalbox | 1 | 08-15-2006 21:02 |
