07-23-2007, 16:49 | #1 (permalink) |
Registered User Join Date: Aug 2004 Age: 44
Member: 76882 Status: Offline Thanks Meter: 56 | 6600 white screen after repace PA 6600 problem with signal , replaced PA. after mobile dead. now condition is when power on only white screen , switch off few sec. again power press white screen . solution please........ |
07-23-2007, 19:03 | #3 (permalink) | |
Insane Poster Join Date: Aug 2006 Location: Beside malaysia Age: 45
Member: 333035 Status: Offline Thanks Meter: 2 | Quote:
Do not touch on lcd socket as u had mention SWITCH OFF FEW SEC... | |
07-23-2007, 19:22 | #5 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | Quote:
do check zucos ic...first its on other side of the board....check with software....post result regards PUNEET14884 | |
07-24-2007, 08:02 | #7 (permalink) |
Member: 76882 Status: Offline Thanks Meter: 56 | friends this is not a display drive IC problem , calls are not working. in jaf & ufs check and info are not done . may be mobile not booting . please give me solution... |
07-24-2007, 23:34 | #9 (permalink) |
Major Poster Join Date: Jul 2007
Member: 549452 Status: Offline Thanks Meter: 13 | [EMAIL="[email protected]] check your lcd jack resold |
10-27-2007, 11:07 | #12 (permalink) |
Junior Member Join Date: Oct 2007
Member: 604998 Status: Offline Thanks Meter: 0 | here is a solution boss firtly u have to take out p.a then check if set is ok it means ur p.a is faulty if not then just change the boot i.c after that just fromat the set by u.f.s or manually don't do anything else iam sure ur problem will be solved do only this don't touch anything else ok bro do care fully and tell me the results ok . |
6600 white screen and shutdown after 33s | fontelense | Nokia Hardware & Hardware Repair | 29 | 11-03-2008 12:56 |
6600 white screen after 30 second !!! | ::.::RAMJAN::.:: | UFS2 + UFS3-Tornadoflasher | 17 | 05-19-2007 10:38 |
6600 white screen after 30 second!! | majidjony | Nokia Hardware & Hardware Repair | 7 | 12-09-2006 13:15 |
nokia 6600 white screen after flashing | pitodenz | Nokia Hardware & Hardware Repair | 0 | 08-06-2006 18:34 |
6600 white screen after tornado flash | ckkckk | WD2 & APE (Symbian Phones) | 1 | 03-25-2005 14:30 |
