Old 03-03-2008, 09:15   #1 (permalink)
Member: 477078
Thanks Meter: 3
Red face 6610 batterylow problem
6610 battery low after 5hour inbattery chargefull
Old 03-03-2008, 19:16   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
I think you check the battery first if battery ok then
check the bat connector , if not solved clean the pcb in ctc , if same then replace PA (also check short capasitors)
post result
Old 03-04-2008, 06:46   #3 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
1. change battery
2. change pa
post your result
Old 03-05-2008, 08:35   #4 (permalink)
Member: 477078
Thanks Meter: 3
sir this problem not when call after few hour not tobe use set off caus battery emty hlp me pls
Old 03-05-2008, 08:39   #5 (permalink)
Member: 718813
Thanks Meter: 15
this will work:
-- change battery connector.
-- reball UEM IC
-- replace PA if problem persist.
Old 03-05-2008, 09:17   #6 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
change pa and post your result
Old 03-06-2008, 09:49   #7 (permalink)
Member: 477078
Thanks Meter: 3
i have chainged batterY conoctor and reballede UEM Problem still pls upload PA JUMPERING 6610
6610 display problem mobilemafia Nokia Hardware & Hardware Repair 10 01-07-2009 18:51
nokia 6610 reception problems HELP Ebola Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-08-2003 01:48
Nokia 6610 Unlocking problem Giulianiarad Nokia Digital Core Technology 4 ( DCT-4 ) 3 11-02-2003 00:57
6610 power problem saif@cellplus Nokia Digital Core Technology 4 ( DCT-4 ) 0 06-25-2003 10:02
6610 flashing problem ezfreek Nokia Digital Core Technology 4 ( DCT-4 ) 2 05-30-2003 02:34
Page generated in 0.15400 seconds with 10 queries
