6610 keypad not working ? help me Hi ! I have a 6610 nokia no key in the keypad is working I have checked the volume buttons but the problem is that small ic near key pad connectors I think it is called Matrix ic is not there, some one have removed it, is there any solution to bypass that ic and make jumpers to work the keypads again |
Theres no other solution - you must replace the small IC. |
you can replace that glass ic with one from nokia 8310! it works 100% |
Sir any other Ic matchses with 6610 model ? cause I dont have 8310 ic |
I have placed the Ic from a dead 6610 board but still no button is functioning plz help |
Are you 100% sure that the IC correct installed? IF yes, then next step is try one more chip, then check UEM and CPU. This class chip is used on many dct4 phones. All are the same. |
BR |
i replace volume switch, replace EMI keypad. but keypad not work at all. What should i do? |
dear 6610 ka menu butan aor exit butan kaam nahe kar rahe . pls give the salution if u know. |
