Old 04-26-2008, 10:01   #1 (permalink)
Member: 758730
nokia 3500 no sim card prob
nokia 3500 water damaged phone
phone is working perfectly but
after insertion of simcard
phone is asking to start without simcard
plz give me sol for this problm no sim card inserted
plzzzzzzzzzzzz help me for this problem..................
The Following User Says Thank You to rajesh4302 For This Useful Post:
Old 04-26-2008, 10:05   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Check the sim connector.
If it is show damage or faulty change the connector.
Post result.
Old 04-30-2008, 13:27   #3 (permalink)
Member: 511560
Thanks Meter: 66
mostly is the sim ic damaged beside the sim holder
Old 05-22-2008, 11:55   #4 (permalink)
Member: 749779
Sonork: the_t_khan
Thanks Meter: 3
hello brother i was faced this same problem
im replacing sim jack
now im very happy u can also do like that
otherwise replace sim ic
The Following User Says Thank You to the_t_khan For This Useful Post:
Old 05-22-2008, 12:36   #5 (permalink)
jolie's Avatar
Member: 570581
Thanks Meter: 223
hi bro try to clean board and try flash
The Following User Says Thank You to jolie For This Useful Post:
Old 06-16-2008, 06:35   #6 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
bro try to clean board and try flash,...............
The Following User Says Thank You to sujan1050 For This Useful Post:
Old 10-06-2008, 10:22   #7 (permalink)
Member: 666690
Thanks Meter: 2
the phone is not working because it have a water damage this does mean that it is a hardwer problem not a softwer problem.
Try to change the sim IC
GoooooD Luck.
"M-To The-C."
The Following User Says Thank You to mini-clip For This Useful Post:
Old 09-01-2010, 07:25   #8 (permalink)
Member: 1383710
dear frind, plase send 3500c insert sim solution
The Following User Says Thank You to alexjose. For This Useful Post:
Old 09-01-2010, 10:35   #9 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
brother is a sim IC problem ; replace sim ic
The Following User Says Thank You to $h@hidmobile$ For This Useful Post:
Old 09-01-2010, 10:42   #10 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
bro remove SIM Ic. Check all track sim ic to Sim base. any track Broken gives Jumper.or all track is Ok Then Rehot retu.
nokia 3500 insert sim 4 u man Nokia Hardware & Hardware Repair 7 01-11-2010 08:47
Nokia 6103b insert sim card. restricted sim card.... But phone was unlocked! -luigi- Nokia Digital Core Technology 4 ( DCT-4 ) 1 10-05-2009 23:43
Nokia E75 No Sim Card Error wizmanoj Nokia Hardware & Hardware Repair 0 06-22-2009 21:03
Siemens c25 no sim card with sim card.... florinmar Siemens Hardware Repair Area 2 04-10-2002 03:14
Page generated in 0.14528 seconds with 9 queries
