02-13-2006, 11:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Czech Republic
Member: 3714 Status: Offline Thanks Meter: 6 | 6610i cant flash - unknown flash manufacturer i have one 6610i which writes common problem when i tryed to flash it: Flash configuration: 9F0201709DB61A00000BC20000020000... Failed to find FIA file in 'c:\griffin\flash\ In 99% of the cases this is caused by corrupt FLASH folder. Fully DELETE the contents of the Flash folder, and then Install the latest FIA package! Error[78878778] or with tornado: 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x00FFFFFF,00000001, Algorithm: Unknown 2nd Boot Error: Error Data1: 00000000: 9F 01 02 01 00 00 00 01 00 00 00 00 00 00 02 00 ................ 00000010: 00 00 01 00 00 00 00 00 00 00 00 00 01 00 02 00 ................ 00000020: 03 00 04 00 05 00 06 00 07 DB 00 00 00 00 00 00 ................ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: 01 00 00 00 01 00 00 00 00 00 00 02 00 00 00 01 ................ 00000010: 00 00 00 00 00 00 00 00 00 01 00 02 00 03 00 04 ................ 00000020: 00 05 00 06 00 07 DB D3 72 00 00 00 00 00 00 00 ........r....... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ I tryed to change FLASH IC as usualy but it doesnt help, then i tryed to change UPP and UEM from another working phone but still the same... i tryed to search this forum but i didnt find any solution it is not first phone with this problem i have here any idea? Thanks Platy |
02-13-2006, 12:46 | #2 (permalink) |
Major Poster Join Date: Jan 2006
Member: 226582 Status: Offline Thanks Meter: 3 | solution of 6610i cant flash - unknown flash manufacturer flash on this window(win98)your fone will be write flash and working 100% ok if your mobile did not write flash re sold of flsah ic and try again enjoy it |
02-14-2006, 01:40 | #4 (permalink) | |
Freak Poster Join Date: Jul 2003 Location: Germany / Rhauderfehn Age: 60
Member: 35205 Status: Offline Thanks Meter: 14 | Quote:
update and/or copy new fia-files ---> c:\griffin\flash | |
02-14-2006, 18:55 | #5 (permalink) |
Member: 3714 Status: Offline Thanks Meter: 6 | No, its not a SW problem!! I tryed that FLASH IC in other phone and it can be flashed without any problem, only in this phone it writes this error.. Platy |
02-16-2006, 08:51 | #7 (permalink) | |
No Life Poster Join Date: May 2005 Location: Baguio City, Benguet
Member: 149576 Status: Offline Thanks Meter: 57 | Quote:
02-17-2006, 17:25 | #8 (permalink) |
Member: 3714 Status: Offline Thanks Meter: 6 | I wrote above that i tryed to change UEM, FLASH and UPP without any result :-( it is not only this phone, i have actually 3 units here with the same probl. looking like flash ic bad, but after change flash, uem, upp still the same |
02-17-2006, 23:48 | #9 (permalink) |
No Life Poster Join Date: May 2005 Age: 48
Member: 146798 Status: Offline Sonork: 100.1576177 Thanks Meter: 24 | this problem as readed by tornado means u have bad flash ic if u check it or change it check the feeding voltage for flash ic or broken lines between upp-flash ic ur problem only around flash ic & its connections |
02-18-2006, 13:10 | #10 (permalink) | |
UEM new ??? then you need RPL-File change UEM from a working phone is stupid, you must use a blank UEM and flash a rpl-file to it. search UEM-change | |
02-18-2006, 15:07 | #11 (permalink) | |
Banned Join Date: May 2003 Location: quezon city
Member: 28889 Status: Offline Thanks Meter: 16 | Quote:
03-14-2006, 14:27 | #14 (permalink) | |
Member: 34310 Status: Offline Thanks Meter: 23 | Quote:
Ur Flash IC was broken or damaged or don't have VIO ! Check VPP and VIO again !!! If OK, rework or change flash IC. Sometime UPP have trouble too. Good luck Vinh Hai | |
Unknown Flash Manufacturer | abdoune | n-Box | 9 | 10-16-2006 22:35 |
Unknown flash manufacturer | cyklops | Twisterflasher | 5 | 12-27-2005 04:53 |
Unknown flash manufacturer | snowhite | Nokia Hardware & Hardware Repair | 9 | 10-25-2005 17:01 |
Unknown flash Manufacturer | tawanda | Twisterflasher | 1 | 11-15-2004 10:14 |
6600,Unknown Flash Manufacturer | VsH-GsM | UFS2 + UFS3-Tornadoflasher | 7 | 07-31-2004 18:05 |
