03-07-2007, 05:02 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 39
Member: 119200 Status: Offline Thanks Meter: 56 | 6630 hang&restarts |
03-21-2007, 00:37 | #2 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | Yes very strange.I recieve today one 6630 with restarting problem after some time 30sec-2min.Custumer only put mmc dv (card is OK) from other phone and after that hi get this problem.More strange is when BT is ON phone don't restart. I flashed/formated phone so don't post crab as flash or format phone or mmc. Could be problem in PM area? Can this mmc by mistake write something in PM area? And how is safe to write other PM file and not to lock phone or f-uck imei? wbr. |
05-21-2007, 20:13 | #4 (permalink) |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | the common problem in bb5 sets are hang,restart,white display etc.every budy gives different suggestions but every time same problem different solution works.e,g; take restarting problem some time it solve by changing ram ic,some times solve by omap sometimes it may solve by vcore voltages.it means we have to check one by one for these type of problems. |
06-08-2007, 10:35 | #9 (permalink) | |
Registered User Join Date: Jul 2005 Location: kanagawa, japan Age: 51
Member: 163924 Status: Offline Thanks Meter: 3 | which parts is SMPS-IC and Vcorea Quote:
Could you kindly tell me which parts is >> SMPS ic and chek Vcorea? Thank your kind attention best regards, | |
06-08-2007, 17:53 | #10 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Uttaranchal Age: 35
Member: 181696 Status: Offline Sonork: 100.107830 Thanks Meter: 5,406 | Quote:
Br Archit | |
06-08-2007, 19:19 | #11 (permalink) |
Member: 483748 Status: Offline Thanks Meter: 47 | maximum times due to vcore a voltages is responsible for hang ,restart etc.it is important to check the accuracy of vcore A voltage 1.4 not less then that( smps ic ).try this solution it is useful. |
06-10-2007, 05:46 | #12 (permalink) |
Member: 163924 Status: Offline Thanks Meter: 3 | Thank you so much Dear Sir ..::ArchitRaj::.. Sorry my late response. Your post was noted. Thank you so much your kindly attention and very valuable information. I'll try to do it. kind regards, |
06-10-2007, 06:21 | #13 (permalink) |
Member: 163924 Status: Offline Thanks Meter: 3 | Dear Sir ..::ArchitRaj::.. Sorry often my post. After your advice I review 6630SM again then I found attached description. I'll read carefully by myself in next time. best regards, |
06-10-2007, 09:34 | #15 (permalink) |
Junior Member Join Date: Apr 2006
Member: 260312 Status: Offline Thanks Meter: 1 | 6600 restarts dear sir Architraj, i have a 6600 restart problem.i formatted it but no result then i flashed it but while flashing it shows like bt image not found or bluetooth error. then i tick marked skip bt optoin then flashed it.but still it restarts after every minute or two. any solution pls |
n72 hang&restart | .:SARCAR:. | Nokia Hardware & Hardware Repair | 1 | 05-04-2009 13:07 |
x 620 hang&restart | shafeeque | Samsung Hardware Repair | 0 | 12-30-2008 08:23 |
6270 hang&restart on startup | BABAK NURI | Universalbox | 8 | 07-02-2007 21:28 |
6630 upgrade to 6630 music edition??? | namnguyen | Nokia Base Band 5 ( BB-5 ) | 0 | 09-14-2006 12:38 |
