6670 only key 2,5,8 are not working..help is considered i have 6670. after i flashed the set now its ok. (from white screen) but now another problem is coming. the key 2,,5,,8 only not working...others work fine.. please help.. |
heat normal k-pad ic (near of k-pad conector) |
1 Attachment(s) hi brooo check this photo |
1 Attachment(s) sorryyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy |
firts check the connection of the keypad..if not good chages keypad ic. |
yes 6670 & 7610 is same......................... |
2 Attachment(s) Quote:
if it ok then rebaw with flux left side ic . wbr |
thanks bro i will try it |
