05-09-2005, 05:56 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | 6670 problem, need help BR Shakeel |
05-09-2005, 10:12 | #2 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | bad, very bad mmm... it smells uem crashed (or upp could be too), try a format user area if box doesnīt communicate with the phone it is a uem matter. Go official warranty. |
05-10-2005, 09:58 | #3 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | i full flashed the mobile today , and formatted USER area , all goes 100% , now mobile have latest version but still problem occuring , i noticed that this problem won't happen if battry signals are full but starts happening when first battry signal drops. Please suggest something BR Shakeel |
05-11-2005, 09:18 | #4 (permalink) | |
Freak Poster Join Date: Jul 2003
Member: 34310 Status: Offline Thanks Meter: 23 | @ shakeelajmal Quote:
U try to full erase and flash again. When finish 1. Format user area. 2. Write good PM. 3. run UI option but not choose "Full factory default". If OK u can see "Nokia" when u connect ur phone with box B.R Vinh Hai | |
05-11-2005, 09:41 | #6 (permalink) | |
B.R | |
05-11-2005, 11:15 | #9 (permalink) | |
Member: 51639 Status: Offline Thanks Meter: 76 | Quote:
BR Shakeel | |
05-11-2005, 18:57 | #10 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | after exectly 8 hours , problem again occured , mobile restarted , then turned off automatically , and when i pressed power button nokia appears and disappeared thrice then again mobile went off. is this UEM problem ? if yes then who can help me to solve this problem . BR Shakeel |
05-12-2005, 07:57 | #11 (permalink) | |
Member: 34310 Status: Offline Thanks Meter: 23 | Quote:
Perhaps UEM or UPP has problem. If U have Soldering Stations U can solve it by yourselft. I think u have because u also have UFS. Firstly u will rehot them and try to use. B.R Vinh Hai | |
05-21-2005, 00:16 | #13 (permalink) | |
If i tell for u to make it then u can do it by yourselft? I think UEM or UPP need resolder. U can read this post: http://forum.gsmhosting.com/vbb/showthread.php?t=157093 Good luck. Vinh Hai | |
05-27-2005, 08:34 | #14 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | first of all thanks for the detailed help, 2ndly i am not good in hardware , i tried to found some good hardware man , but no one was ready to help me in this case , so i just rehot (slightly) the UEM and close phone , now phone is working , it does not show any problem , three days and 2 times battry went low but the problem didn't occured , i don't know how long this will work or when i need to reball the uem but i can't risk it myself and no one in my area ready to do this either , anyway at the moment its running well, if problem happens again i will contact nokia service center , thanks once again for all the help BR Shakeel |
nokia 6670 problem..plz help | arvindbisht | Nokia Hardware & Hardware Repair | 1 | 05-03-2009 14:26 |
6670 very strange keypad problem needed help | celluniversal | Nokia Hardware & Hardware Repair | 3 | 04-21-2007 13:05 |
n3210, charging problem. need help | pali | Nokia Hardware & Hardware Repair | 3 | 07-04-2002 01:54 |
sony j6 starnge problem need HELP | gsnbhagawan | Sony | 0 | 02-20-2002 07:54 |
Sagem 835 fm big Problem!! need help, please! | Elgravi | Infineon C16X M51 & ARM7 M52 BASED | 1 | 03-21-2001 00:19 |
