6670Phone start-up failed. Please Contact Retailer hi, MY6670 Phone start-up failed. Please Contact Retailer ,all rady formate manul also erase flash, when i flash mobile weanto format user earia but not compelat.stell my phone condation is same. so any solution for me plz help..... |
pls try to rehot UEM, back-up first! gudlock |
make full erase then flash again higher firmware .. if succes make ui ..if still same mild re hot the sram br |
did u try *,3,callingbutton,on off swithch it worked like magic for me in 7610 with exactly same problame. |
all I have done all rady hi, all are those tryed but condetion is same any new solution..plz help |
hi, sachin udai, like same problem I will done so many times but this time can't done.but i think its a verias when want to format user area thats not done.......ufs windows messages format user area failed so how can take care this problem plase help |
1.erase with full erase file 2.erase with sec eprom file 3.erase with user erase file then full flash make ui settings write pm and unlock. |
6670 get solution hi, thanks to all,I solved my provlem.clean pcb and bulb hit 30 munite and erase flash, format user area then ui and is ok.......... |
