04-12-2010, 04:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | 6680 full short? |
04-18-2010, 13:53 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | check shoting in nokia 6680...... 1..remove this z7500 mark in (1) if u want to check the shoting of pf of gsm and wcdma ....if remove the coil and ur shoting is gone then tere is shoting in ur pf of gsm or wcdma ........ 2..remove this coil mark in l7503 (2)...if u want to check the shoting of rf ic for gsm hinku and rf ic for wcdma vinku.... by removing this coil if ur shoting is gone then there is shoting in ur rf ic whether it is hinku or vinku.... 3..remove this coil mark in (3)..if u want to check the shoring cause flash light driver ic n1471 ....because this ic got +b from batery.... 4..remove this coil mark in (4)..if u want to check smps ic n4200.. ..this ic make v corea for omap ic and rap remove cil to check shoting is gone or not..... 5..remove light ic mark in (5) ... to check the shoting cause by light ic or not.... 6..remove n1472 ic mark in (6) ...it is vcamdig maker ic which make v.cam when front camera is activated ......remove this to check shoting because this ic got +b from batery...... 7..remove ic n1470 mark in (7)... it is c camdig maker ic which make v.cam for camera ....remove these ic to check shoting .....because it got +b from batery..... 8..remove ic n6031 mark in (8)... to check shoting ...because it got +b from batery.....this ic make volt for bluetooth...... 9..at end remove retu and tahvo ic to check shoting....... all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic .... |
Full Flash 5130 V05.61 | nokia_flash | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-03-2011 15:38 |
Wanted 6130 4.02 full backup Pls Read | Charly | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-06-2001 05:12 |
6150 Full Flash , Help | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-03-2001 13:34 |
Full flash for 6110 v5.24 needed | tcfx44 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-30-2001 14:04 |
NOKEY BOX FOR SALE - FULL | Zorz | Main Sales Section | 0 | 12-05-2000 10:56 |
