6680 not charge i have this problem with 6680 not charge.The fuse is ok but between + and negative i have shortcircuit.I have change the diode but same problem. Please help. |
search in section ur problem o ready is posted try to search good luck |
1 Attachment(s) Brother Here Is your solution................... |
bro chang tahbo problem will solbd 100% |
6681 nokia is dead or power ic 6 lags .power ic in a board track are damage . thes track not find plzzzzzz solution give me |
Hi my friend thanks for help, i remove the fuse and diode i check but i have always shortcircuit between + and -.How can i repair this problem?? |
without fuse,,solder a wire fromthe charging connector to one end of coil,,be sure to cover the positive pad of the board with a pc of tape,, |
Anyone got a pic of where the fuse is :rolleyes: 100 x thanks in advance John...:) |
