Old 01-06-2009, 04:21   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::6680 this print short with ground::..
nokia 6680 this pin of display connecter short with ground,set problem is no light on lcd and keypad,i change light ic,coil,also reball tahvo but all same
The Following 2 Users Say Thank You to HUM For This Useful Post:
Old 01-06-2009, 13:47   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any idea mates..................................
Old 01-07-2009, 04:05   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
is there any solution?
The Following User Says Thank You to HUM For This Useful Post:
Old 01-07-2009, 04:25   #4 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
its a water damaged?????????
The Following User Says Thank You to toutou_gsm For This Useful Post:
Old 01-07-2009, 05:01   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
no its not water damage
Old 01-07-2009, 05:02   #6 (permalink)
asia_gsm's Avatar
Member: 435412
Sonork: 100.1608142
Thanks Meter: 289
here is 6680 lcd ways
Br.Yasir_Gsm
The Following User Says Thank You to asia_gsm For This Useful Post:
Old 01-07-2009, 05:27   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
no need for lcd ways please read post again
Old 01-07-2009, 06:02   #8 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
i has face this problem before but different phone..
my solution is,
i take out display connector then cut damage print,
put back conn...
at keypad connector,take it out ,cut print pin at connector,
make jumper...
can?
The Following User Says Thank You to fasany For This Useful Post:
Old 01-07-2009, 10:21   #9 (permalink)
Member: 601591
Thanks Meter: 86
Dear hum the best sollution is to remove the lcd connector and cut the ground off so you can now fixed another connecton i hv done many like that in nokia 3230,7610 6630 6600 and they are all works
The Following User Says Thank You to baloo2000 For This Useful Post:
Old 01-07-2009, 10:36   #10 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
try to remove these capistors shown in pic and post result....
The Following 3 Users Say Thank You to digitized For This Useful Post:
2610 lcd one print short any good help... guljee786 Nokia Hardware & Hardware Repair 4 01-05-2010 16:04
..::6030 mic prints are short with ground::.. HUM Nokia Hardware & Hardware Repair 1 11-29-2008 00:32
..::6030 this print needed::.. HUM Nokia Hardware & Hardware Repair 22 11-22-2008 03:02
..::1110i this print missing::.. HUM Nokia Hardware & Hardware Repair 1 12-04-2007 11:39
..::urgently need this print of k750::.. HUM Sony Ericsson Hardware Repair 0 07-16-2007 20:04
Page generated in 0.22372 seconds with 10 queries
