01-13-2013, 03:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2009 Location: Pamplona Negros Phillippines Age: 41
Member: 1147721 Status: Offline Sonork: 100.1624168 Thanks Meter: 13 | 6680 stop flashing help..i already try to full erase no luck.. what ic i'm going to repair? here is the log ... MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C084A371 Using device: HTI, FW ver: 00.50, SN: 010077ED Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14213(16-10-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] EM0 ID: 00000232 EM1 ID: 00000341 PUBLIC ID: 082000113DAA4F57366D6513D0F97F96F395D802 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 eBB5ProtocolType: OLD Storage0: 00EC 22FA - 0000 0011 [Samsung K8S6415ETA,64 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 Processing MCU file: rm36_5.050407_b5.c0r [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 20.25 MB Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100701, 17100702 Erase size: 37.34 MB CMT FLASH,NOR area [00000000-00509139] CMT FLASH,NOR area [006A0000-006BFFFF] CMT FLASH,NOR area [006DF000-006EFFFF] CMT FLASH,NOR area [00700000-007EFFFF] erased in 43.493 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0F72BF9D [Rap certificate3] sent Error chk C7012D0100D0 Error while programming [01] at 0x00000000, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 00 D0 00 |
