Old 11-15-2007, 16:14   #1 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
7260 contact service........
hi plz check log end help me your 7260 contact service...
JAF version 1.98.40
Detected PKEY:Card life counter: 90.03%
P-key nokia module version 01.00
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 3010
Detected P-KEY: P-key nokia module version 01.00
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.900
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90c
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90.image_c
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
Backup IMEI zone...
Setting local mode...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\356218004130983_imei_back up_18491511.rpl
Done!
Getting MCUID...
MCU ID: 0x2142
Reading flash chip detailes...
FLASH ID0: 00208826 -> SEC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
MCU ID: 0x2142
Boot is ready...
Algo is ready...
Loader is ready...
Erasing area: 01000000 - 01FFFFFF...
Done!
Backing up PM Field 208 as RPL...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.900
Booting phone...
MCU ID: 0x2142
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.40.00 -> Revision: 0007
Boot size is 0x0970
Boot is ready...
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0x26882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
Loader size is 0x4B00; Loader chk: 2e
Loader is ready...
MSID: 846D68B517364E1791DC9C8369
MSID decoded: 2C40BAE9009A50B0AA000000
FAID: 20E706D06B33D617B9F3A39A
Operation took 0 minutes 13 seconds...
Erasing...
Found 3 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 0181FFFF...
Erasing area: 01E60000 - 01FDFFFF...
Operation took 1 minutes 25 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 50 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90.image_c
Booting phone...
MCU ID: 0x2142
Boot size is 0x0970
Boot is ready...
Loader is ready...
MSID: 8435B5019F3B68D12DFD1E64FC
MSID decoded: 1C15BAE3009A50B0AD0005BD
FAID: B2B36AFE88191F5409FE530B
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01A40000 - 01E5FFFF...
Operation took 0 minutes 37 seconds...
Writing...
Operation took 0 minutes 12 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Extracting Content Pack...
Running: (c) Nokia File Server
CNT Extract Skiped.
Operation took 0 minutes 1 seconds...
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__05.90c
Booting phone...
MCU ID: 0x2142
Boot size is 0x0970
Boot is ready...
Loader size is 0x4B00; Loader chk: ce
Loader is ready...
MSID: 84B8BA377955611C925E472B3B
MSID decoded: 3E4EBAE9009A50B0A9000000
FAID: 06641A162FCAAABE00B12AA6
Erasing PPM...
Erasing area: 01820000 - 01A3FFFF...
Operation took 0 minutes 19 seconds...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
Flashing Done!
Operation took 4 minutes 25 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-17, Software version: 05.90
IMEI: 356218004130983
Product Code:
Resetting PPC...
Powering the phone...
Unlocking...
ASIC: 2
SW version: 05.90
Checking locks...
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 4679
Reading imei...
IMEI/ESN: 356218004130983
Reseting warranty data...
Reseting LifeTimer...
Lifetime data not found!!!
Done!
Old 11-15-2007, 16:55   #2 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
you can make it work.
mobile phone battery strenght not enough......
1.try recharged your mobile phone battery again.
2. clean the connecting interface on both mobile and cable again and try .
i am waiting for you.
bestman
Old 11-15-2007, 17:26   #3 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
sir i have try clean bourd end re charg battry end flash ufs end jaf flashing done but i put batt.. screen white end black +contacat service
Set Full Factory Defaults Ok, Time: 00:06
IMEI: 356218-00-413098-3, ASIC: 2
SimLocks Initialized, Time: 00:04
Old 11-15-2007, 17:53   #4 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
what version of unlocking / flash software , you are using?.
bestman
Old 11-15-2007, 18:05   #5 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
bestman
sir i have all version use last version 6.20.. but this log 5.90 thankx to fast rep.. end help
5130 contact service (ANSWERED) vishal123123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 08-10-2011 11:05
nokia 6303c contact service help.............. RABIULSK MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 04-09-2010 21:18
nokia 6303c contact service help...... RABIULSK Universalbox 5 03-30-2010 11:31
7260 Contact Service antm Twisterflasher 2 10-22-2005 18:41
Page generated in 0.15335 seconds with 9 queries
