Old 12-06-2006, 19:44   #1 (permalink)
Member: 374225
Thanks Meter: 41
Talking 6681 bluetooth as never faced this prob b4
i have 6681 which says unable to perform bt operation i replaced bt ic and white caplour also above that ic so checked again but still gives me same error i tried to find out its bt add but as i enter code it asks me activate bt in offline mode and again same error plz tell me now wat can i do
Old 12-06-2006, 20:21   #2 (permalink)
Member: 320354
Thanks Meter: 48
try flash that phone
and then write good pm and Repair Blue Tooth
good luck
Old 12-08-2006, 08:51   #3 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
have you tried to replace the filter beside the module????
Old 12-11-2006, 13:17   #4 (permalink)
Member: 157745
Thanks Meter: 4
hi gsm blue ,can tell me ,how to make jumper the filter i.c
Old 12-12-2006, 03:17   #5 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
i think its not applicable to jump the filter.. i try it once but it doesnt work... but after i replace.. it work 100%...
br
Old 05-06-2009, 10:32   #6 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
nokia 6681 bluetooth unable perform bluetooth operation heep meee
Old 05-21-2009, 00:15   #7 (permalink)
Member: 771642
Sonork: aanshu55
Thanks Meter: 28
hello bro just try this ur problem 1000000%solved it is tested by me i m sure that it will be ok if u have not damaged other any components and ics of bluetooth before. i cant upload image here so i have post any others link just click and check.http://www.hi5.com/friend/photos/dis...17_150856220_0
Old 05-21-2009, 00:56   #8 (permalink)
Member: 771642
Sonork: aanshu55
Thanks Meter: 28
http://www.mygsmindia.com/vbb/showth...6681+bluetooth sorry for unavailable pic just click here check jumper pic posted by me
The Following User Says Thank You to aanshu55 For This Useful Post:
+++excellent Work By Infinity Support I Never C This B4+++ makkah mobile Infinity-Box 40 04-22-2008 22:18
6600 i never faced this problem before celluniversal Universalbox 2 04-22-2007 13:42
6600 i never faced this problem before celluniversal Nokia Hardware & Hardware Repair 7 04-22-2007 12:06
"Reading OTP... error B8 " have u never seen this message b4? selfone69 Smart-Clip 1 02-03-2007 18:19
Page generated in 0.18819 seconds with 9 queries
