6681 Error in ape get id help me i have 6681 [waterdamge] with white screen . i removed boot ic and jumpering fallowed by forum , but problem not solved , when flashing with jaf [my jaf recently purchased it have 7pincable for bb5 flashing] .it said Error in ape get id.please tell me which ic problem .or give me any suggestion ,i serched in forum for this problem solution not came |
CHECK THE VIO SUPPLY ON COMBO MEMORY IF THERE IS 1.8V, IF NO VIO SUPPLY MAKE JUMPER TO SUPPLY THE COMBO MEMORY. IF THERE IS VIO SUPPLY, CHANGE THE COMBO MEMORY IC. |
sir i checked 1.8v ok ,i must change combo ic? or any solution |
hi masters,where i make jumper?which is vio component please give me image... thanks.. |
remove vcore ic and short then ok good luck |
hi. i have read your problem regarding your 6681 ,ape problem,,,,,,,,, please try to change omap .because i always encountered problem which is same like that ..... |
hi,which one is vcore ic,how can i jumper?can you give me JPG... thanks in advance.. |
first try rehot or change retu it will be okm 100% sure please try and post result |
ooooooooooommmmmmmmmmmmmmmaaaaaaaaaaaaaapppppppppp ppppppppppppppp |
first try rehot or change retu it will be okm 100% sure please try it....... |
