..::6700c bluetooth always searching and sometimes battery low and white screen::.. 6700c bluetooth not working always searching sometimes battery low and white screen |
any solution mates......................? |
pro try to flash it i hope it will be good |
already flash the phone with higher version |
by jaf or what ? if you use another try with jaf or mt |
flash with atf and mxkey |
hi mybe bluetooth ic problem first try to change bluetooth ic then chack it ..... |
1 Attachment(s) Check with code *#2820# whether it giving BT address or not. If yes then BT ic must be ok. Check BT antenna track |
