6700S phone start-up failed 6700S phone start-up failed hi 6700S phone start-up failed Phone Type: RM-576 (Nokia 6700s) SW Version: V ICPR82_10w18.4 25-05-10 RM-576 (c) Nokia Imei plain: 35339004940632-3 Product Code: 0589264 ApeCoreSw: 033.014 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353390049406323 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF :eek::eek::eek::eek:please help |
Dear! Format with 3 key! or use hardware problem...........tnx 4 u |
6700S phone start-up failed please help |
Did you flash successfully? Got try changing the flex cable? |
tested from me, 6700s Rm-576 problem is star up failed.. flashing with many box software finish or sucses flashing.. but my 6700s still phone star up failed ! why ? solution rehot rapuyama ic with temp medium my hot air(level 3-4) in 15 sec... testing to start my 6700s... ok 100% problem solved. |
why ? solution rehot rapuyama ic with temp medium my hot air(level 3-4) in 15 sec... testing to start my 6700s... ok 100% problem solved. Which ic should i rehot? Please reply me fast |
rehot 100% ok................................................ ..... |
Brother first try to change the Battery, then post result... |
