Old 12-20-2007, 00:40   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::nokia 1200 lcd light problem::..
nokia 1200 when i power on,keypad and keypad light ok,but in second the display light turn off,krypad light is ok,i change strip,lcd and also chk prints all is ok,but still display light problem.
..::HUM::..
The Following User Says Thank You to HUM For This Useful Post:
Old 12-20-2007, 01:27   #2 (permalink)
faisi's Avatar
Member: 143322
Thanks Meter: 35
check also in settings!
Old 01-05-2008, 10:14   #3 (permalink)
sms-india's Avatar
Member: 156414
Thanks Meter: 60
1200
check light ic.............................
The Following User Says Thank You to sms-india For This Useful Post:
Old 01-05-2008, 10:36   #4 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
..::HUM::..
hi bro,yesterday i have same problem and the problem solved,do fullerased then flash again and wr good pm...
good luck
The Following User Says Thank You to joni_yang For This Useful Post:
Old 01-05-2008, 13:58   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
problem solved by strip.
..::HUM::..
Old 01-05-2008, 16:05   #6 (permalink)
Member: 356169
Thanks Meter: 34
thanks good works..............
Old 01-10-2008, 21:46   #7 (permalink)
Member: 669218
Thanks Meter: 11
than******x for info u hv change strip i also this idea thanx
Old 01-22-2008, 14:29   #8 (permalink)
Member: 280951
Thanks Meter: 2
nokia1200 ......8and 9 keys not worked ic is ok but a print not in under ic
Old 08-11-2008, 13:21   #9 (permalink)
Member: 594055
1200 display track
1200 display track
1200 display track
The Following User Says Thank You to kashish_karan For This Useful Post:
Old 08-12-2008, 07:41   #10 (permalink)
Member: 708659
Thanks Meter: 15
thanks,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 08-15-2008, 18:46   #11 (permalink)
Member: 654510
Thanks Meter: 21
hai sir.may be it is the led if one led is not connected well it will also shows this problem....post replay.
The Following User Says Thank You to naima For This Useful Post:
Old 08-15-2008, 18:56   #12 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
Thanks Meter: 737
bro it is 50% light of from setting in profile or do full factory.
with bes wishes
Old 11-30-2008, 07:12   #13 (permalink)
saqib_islam's Avatar
Member: 446881
Thanks Meter: 707
Brothers your problem is 100% solved here. Just check these links.
Nokia Nokia 1200-08 Lcd Display Lights Problem
Mobile Repairing Picture Help
The Following 2 Users Say Thank You to saqib_islam For This Useful Post:
Old 10-22-2009, 08:06   #14 (permalink)
mothertelecom's Avatar
Member: 1033714
Sonork: 1640811:mothertelecom
Thanks Meter: 91
1200 lcd problem plz help me boss
The Following User Says Thank You to mothertelecom For This Useful Post:
Old 10-22-2009, 10:06   #15 (permalink)
shaazad's Avatar
Member: 1146078
Thanks Meter: 96
its lcd jeak not working change it
1200 no light on lcd and keypad solved sigma xi Nokia Hardware & Hardware Repair 9 04-29-2013 05:43
..::nokia 2600 lcd problem::.. HUM Nokia Hardware & Hardware Repair 0 01-02-2009 20:07
1110i-1200 lcd light A sna Nokia Hardware & Hardware Repair 12 11-30-2008 07:29
..::nokia 1200 Lcd Strip Connections::.. HUM Nokia Hardware & Hardware Repair 9 02-02-2008 13:02
Page generated in 0.21693 seconds with 9 queries
